0 Members and 126 Guests are viewing this topic.
Jeg
Quote from: Void on February 15, 2016, 02:57:02 AM
Hi Jeg. Thanks! It sounds like this is the type of circuit I am looking for.
Have you tested this circuit yet? Does it give you a full 0 to 90 degrees phase shift?
If so, I will go ahead and order the parts... :)
Phase shifting degrees, depend on the frequency that you work with. At 17Khz in which i use it, gives much more than 90 degrees shifting. Just change the cap of 3,3nF to a 47nF one (as Itsu had spot it) and you are ready to go. Yes i test it before two days up to the output of 74hc132. Works fine!
ps. It uses an inverting mosfet driver..
Void
Quote from: Jeg on February 15, 2016, 03:07:25 AM
Phase shifting depends on the frequency that you work with. At 17Khz in which i use it, gives much more than 90 degrees shifting. Just change the cap of 3,3nF to a 47nF one (as Itsu had spot it) and you are ready to go. Yes i test it before two days up to the output of 74hc132. Works fine!
Awesome. Are you testing Allega's PWM driver circuit with PLL as well?
I guess that's called the green box circuit? :)
Jeg
Quote from: Void on February 15, 2016, 03:19:25 AM
hehe yes the green box! No, I don't use Allega's pll as our beta tester (Itsu) wasn't happy with. Instead he drove it straight out of 494 which made it simpler and easier to use.
Void
Quote from: Jeg on February 15, 2016, 03:31:35 AM
Thanks Jeg. That's good to know. I will probably go with the TL494 driver circuit as well.
For now however I will be testing with just the phase shift circuit. Want to run some basic
tests with some simpler setups to see if I can figure out what kicks in the OU. :)
itsu
Quote from: skywalker66 on February 14, 2016, 06:03:36 PM
Itsu,
if you disconnect snubbers or/and the 2 tvs (D7, D8) the lag between gate and drain keep the same ?
Usually snubbers are placed across coils and much less sourse-drain of mosfets.
Try at first disconnecting the 2 tvs and note the difference, and then snubbers.
Hi Sky,
you are probably right, i too think that something in this snubber setup is causing this, i will try to find out by eliminating one by one.
Itsu
