0 Members and 109 Guests are viewing this topic.
AlienGrey
https://www.youtube.com/watch?v=bXwfFV4DIyk
Published on May 3, 2015
* Push the lamp from the pool is not 60V, and 95V .. (Well I vskidku said that .. 60V)
* c high-voltage part, somewhere around 190-200V, but the system is not configured, assembled to show you the effect of HV ..
Dont get too hooked on this one, and read the comments on the page.
NickZ
   Urfa.
    You removed your video???
URFA
Quote from: NickZ on February 15, 2016, 06:56:49 PM
   Urfa.
Yes, I removed.Because  I don't want to be misleading. That video is not important.
URFA
Quote from: Void on February 15, 2016, 05:33:08 PM
Hi URFA. What I was referring to was based on what you stated here previously in regards to
earth ground not improving the performance of your setup in any significant way:
"I think it is not necessary connected to earth (To my way of thinking ) I don't any different effect when I connect it to ground."
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg423137/#msg423137
"I have effect of the ground now in my experiments.  But when my power supply connected to the network effect is bigger. And when I use battery,the effect of the ground verry little."
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422658/#msg422658
Previously you stated:
"In my setup.
Power consumption of kacher: 24 V  1.8-2 A
Power consumption of push pull driver circuits: Without kacher 24V 2A but I measured when kacher runing Its power consumption is growing about 24V 7-8 A.
Power consumption of kacher and push pull driver totally 9-10A(24V)
I have 4x40w and 1x100w  220v light bulbs. Totaly 260w and When kacher run they are fully brightness.
My setup not OU.I only share this video with you to show the effect of Kacher. I'm still working on this system like you."
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg421773/#msg421773
I guess you are you talking about a different test later where you powered 420W of light bulbs?
If you really measured 190V at 2.2A (potentially around 418W, i.e.  if no phase angle) to the light bulbs, with 264W input power consumption, then yes,
that would an interesting result. Were they all filament type light bulbs, or were some of the lights other types?
Were you powering from a battery or mains connected power supply?
Where can info be found on Alexee Sergey? His name sounds familiar...
All the best...
Hi Void.
Hopefully I can express myself in English.
I made many experiments. I tried sometimes ridiculous experiments.Sometimes I have tried many different things from Ruslan's(Akula) system.
So I got very different results.I did not write them all here.Some of my experiment did not influence the ground.
But the grounding had an impact in some my experiments. Many times was greater the input power than output power.
But I obtained 24V 11A input and 190V 2.2A output. I did different experiments for higher output power.But after I changed my setup, I could not achieve the same results in a more. Because I was constantly making changes my setup.I used filament type light bulbs in my all experiments.
I burn nearly the 20 power supply in my experiments. I sometimes use battery and sometimes grid.In both I used.
About Alexee Sergey. He is succesfull Ruslan-Akula setup. No more information is currently about him on the
Internet.Information deleted. GeoFusion shared his scheme on this forum.
I attack some of Sergey's picture and schemas.
İbrahim
URFA
