0 Members and 145 Guests are viewing this topic.
verpies
Quote from: T-1000 on February 23, 2016, 04:11:08 AM
We need circuit doing Fn = 1..10 * F0 * 10 + 1..10 * F0 multiplying function. Where F0 is the input frequency from PLL and the output frequency range is from 500kHz to 5MHz.
So you need a f0*(11..100) frequency multiplication in steps of 1*.
So what is the problem?
T-1000
Quote from: verpies on February 23, 2016, 07:28:20 AM
We need multiplication by 10 for crude adjustment and multiplication from 1 to 10 for fine adjustment such as:
10f 11f 20f 50f 64f 87f 100f where the f is base frequency.
For raw f1...100 there is design problem without micro-controller. Also it is harder to sweep over range of harmonics when looking for unknown resonant harmonic number.
With Kapanadze replication there so many variables and this circuit block aims to eliminate 2 separate generators which de-tune very quickly to each other after circumstances change.
P.S> After this circuit is ready you can apply it instantly to parametric resonance, TPU, HHO and many other things where the low frequency carrier wave contains high frequency modulated resonant wave...
Dog-One
Quote from: magpwr on February 23, 2016, 07:22:44 AM
At the moment i do have ideas in my head on how to design a optional Earth current detector on one blue toroid which can output to 3 Leds Red,Amber,Green using 3 separate 1 turn coil on 1 toroid.
I didn't mention it when you first posted, but I want to commend you on this idea magpwr.  It truly is absolutely brilliant and I cannot understand why no one else thought of it to compliment clamp meter readings.  It's such a simple idea yet it has powerful implications that current is/must be actually flowing in the earth ground cable.  No denying it now.
So a battery operated device that is completely isolated from any other power source can create a "current signature" between itself and an earth ground.  If we cannot take this understanding and do something novel with it, we are simply not trying hard enough.  All we need now is to find the parameters where this current exceeds the current required to self-oscillate and we should be home free.
Great work!
@T-1000:
I'll begin looking for a frequency synthesizer chip.  Hopefully it will be a drop-in device capable of the properties you have highlighted.
I think we have plenty of choices:
http://www.digikey.com/product-search/en/integrated-circuits-ics/clock-timing-clock-generators-plls-frequency-synthesizers/
NickZ
  I received a PM from Nelson, and here are some of his comments to me.
  First of all he has been sponcered by a certain German company to work on the input source device for a 60kw electric car motor.
  So, he is moving there to continue this work, but with all the necessary equipment needed which will be provided to him for this purpose.
"Regarding my statement and in the context of the conversation what I mean is a core of a transformer as a yoke ferrite core is makes no difference if not excited in the right way .
In some experiences that lead so the end of a few minutes is visible producing visible effects in the core vibration and the frequency is variable not fixed. It seems to be needed this variable frequency to change certain states of resonance of the core.
You must have a parametric oscillator as its frequency varies according to certain constants that vary throughout the process."
        end quote.
   Ok, thanks for the information Nelson.  I hope that you achieve your goal, and I also hope that you continue checking in with us here in the future from time to time.
   Anything that you can tell us is always appreciated.
   BTW,  I do listen...
AlienGrey
Quote from: NickZ on February 23, 2016, 09:26:11 AM
        end quote.
   BTW,  I do listen...
this is a bit off tread, but Look up E V Grey squeeling pig circuit !, i did post it some time back !
