0 Members and 370 Guests are viewing this topic.
AlienGrey
Quote from: Jeg on February 25, 2016, 08:35:54 AM
Hi T1000
I think that even at normal high frequency transformers you can not avoid tuning. But definitely your idea worth to try!
Let me ask you something more. How will you overcome the fact that Grenade doesn't give peaks at any high frequency?
It has each own inductance, capacitance, and specific length which give a good rise only to one frequency and some of its harmonics which belong to the same set of frequencies (associated to wavelength). If your low frequency will move, and a change of  high frequency will follow (according to the given relation 1:100 for example), then your high frequency emission will move out of the right set of frequencies. You can't force easily grenade to oscillate at any high frequency. What are your thoughts about that?
Simple use PLL to lock high 'fixed Freq so lower vfo tracks to higher on and not the other way round ! ;)
AG
Any one see New york cops takin fresh food from shops and sling ing it on trash karts ????? whats in the water ?
T-1000
Hi T1000
The rough frequency match becomes easy when you have ability just to pick harmonics on which you want to glue signals. The TT part then can be adjusted to the operating frequency range after. You won't get kWs of power instantly but even when it is unity it is a good start.
Here is interpreted Ruslan explanation:
For grenade coil frequency - you can attach inductor directly to push-pull driver. Then get grenade output almost to few ohms load and sweep through range until start seeing current sudden rise on current sense transformer on grenade coil and some current on ground wire. Then lower voltage on inductor and try again. Then you will know the grenade frequency. After this the induction cooker resonance must match this frequency to work when the grenade coil when it is in full circuit.
Cheers!
T-1000
Quote from: AlienGrey on February 25, 2016, 08:56:54 AM
AG
And you start  driving PLL with lower frequency. When the load is applied on transformer, the inductance is falling so the frequency is going up.
Dog-One
Need to ask Arunas,
The Dally coil is considerably different construction from the grenade coil design.  It too appears to function very similar.  Can you generalize your principles enough to see how both devices must work?
T-1000
Quote from: Dog-One on February 25, 2016, 09:51:39 AM
Need to ask Arunas,
Please see http://img1.liveinternet.ru/images/attach/c/6/91/684/91684491_large_100_6335.JPG
http://img0.liveinternet.ru/images/attach/c/6/91/684/91684492_large_100_6336.JPG
Notice opposite windiings there on the edge of the coil... :)
It was puzzle for me a long time why is that. When you compare to grenade coil the details become much more clarified.
Also Dally implementation on primary coil was without series resonance - it is direct on windings. The free-wheeling LC with fine wire was doing coil magnetization job like with series resonance it seems.
Cheers!
