0 Members and 161 Guests are viewing this topic.
T-1000
Hi verpies,
The R2 should be replaced with fast switching diode to drain gate charge fast as possible. That will kill ringing when mosfet driver switches on its lower internal mosfet for this. The higher internal gate-source capacitance of MOSFET usually is a cause.
The http://www.ti.com/lit/an/slpa010/slpa010.pdf have more info in this topic.
Cheers!
verpies
Quote from: T-1000 on March 10, 2016, 04:42:02 AM
Following that train of reasoning - why not eliminate the gate resistors altogether?
T-1000
Quote from: verpies on March 10, 2016, 06:52:48 AM
Each MOSFET gate-drain have maximum peak current which need to be limited on power-on. On power-off the maximum value will not be reached so this is is why it is safe to create direct gate discharge path.
P.S> You can see such implementation in Tesla driver I posted previously.
verpies
Quote from: T-1000 on March 10, 2016, 07:00:28 AM
Each MOSFET gate-drain have maximum peak current which need to be limited on power-on. On power-off the maximum value will not be reached...
Why will it not be reached during "power-OFF" ?
Since the gate current flows only through R1 during "power-ON" and only through R2 during "power-OFF", why did you recommend a diode in place of R2 ?
By following this train of reasoning - wouldn't the complete elimination of R2, discharge the gate even faster?
T-1000
Quote from: verpies on March 10, 2016, 08:08:04 AM
Since the gate current flows only through R1 during "power-ON" and through R2 during "power-OFF", why did you recommend a diode in place of R2 ?
In that case, just build driver board like it is shared and said, then you can see it that works... ;)
The Tesla coil driver works perfectly in my place by the way.
