0 Members and 345 Guests are viewing this topic.
Tomtech29
HI.
"Cool mosfet's working temperature, happens also to my lossless build. It is surprising enough if you have used to boil eggs over your mosfets with the dissipative designs!!!  :D"
It seems to me that you are using a thin wire section on the primary winding of the yoke,whether it reflects a smaller output current?
the only element that heats up the (filter )will choke! which transmits more power to the yoke.
By the way Itsu interesting but it is not known what will happen when there are overvoltage higher voltage to the yoke 28 of the winding after switching HV or not heat?
- how much do you really amps supplied to the inductor, the heater ,there are about 12Amper?
P.s Why optimal 40 Watt testing and not /100W?
Hoppy
Quote from: Void on March 19, 2016, 06:37:38 PM
Hi Hoppy. I don't know what you mean about 'another' x-wire possibility, as the your first x-wire
is not likely at all a wire. ;D This one doesn't look like a wire either, but I don't know what is sticking out there.
Edit: When I looked again at that fan leg, it looks like maybe the end of the leg is broken off and what we are seeing
sticking out there is just the bottom of the angle iron/plastic where it is not broken off, but I am not sure about that.
It kind of looks that way under closer inspection however.
Personally I am not too concerned about x-wires with Kapanadze because people have been allowed
to view his devices in person and up close and did not see any x-wires. The group that did that earlier
aquarium video were able to inspect everything very closely outside the aquarium, and they only had
one electric heater connected to the output, if I recall correctly, so any hidden wires should have been
pretty easy for them to spot.
P.S. If Kapanadze wanted to hide a wire, you'd think he would actually have hidden it out of sight of the
camera rather than leaving right in view of the camera, no? :)
Yes, of course it would be rather dumb to leave an 'X' wire visible, especially when there are several ways to route a hidden wire or two into the device given the type of environment we see in that video. However, its also possible that slip-ups happen and wires get exposed through carelessness. Its therefore not necessarily strange that the lamp array panel was moved to show a glimpse of the wiring behind it and the table and device were lifted and yet neither the electric fire or the fan were moved out of position. Hopefully he will do a much more believable update video for 2016.
I disagree with you in respect of the Aqua2 video, as there is no video evidence that the earth braid was disconnected and fully inspected inside. If Kapanadze really had a self-runner that functioned with a single conductor earth, surely he would have delighted the inspection team by allowing a full disconnection and inspection with video evidence of this event and even footage that showed the device running with it disconnected, as it was claimed was possible. An event of this importance would almost certainly have been captured on video had TK allowed it. We have to presume that permission was not granted.
PS: Further manipulation of the images confirm to me that neither are wires / cables.
verpies
Quote from: Jeg on March 20, 2016, 04:20:17 AM
1. You have said that you supply with 15V your TL494?  Then wouldn't be more appropriate to feed your drivers also with 15V instead of 12V?
Good point.  That's what I would do if the driver could accept that supply voltage ...albeit fed from a separate regulator, choke and stiffening caps.
Jeg
Quote from: Tomtech29 on March 20, 2016, 06:06:35 AM
Hi Tomtech. See at the attached video my wirings. No thin wires. 2,5mm2 for each of my primaries, 12 T per primary. As with Ruslan's push pull.
https://www.youtube.com/watch?v=zvJnEqeZAYo
itsu
Quote from: verpies on March 19, 2016, 10:05:57 PM
But how do the drain waveforms look like now?
Well, these waveforms look similar as the ones with the old layout, but i will take some screenshots.
QuoteDo you remember what the 45.5MHz can mean ?
yes, you mentioned this before:
QuoteRemember that solid ferromagnetic Iron resonates at 45.5MHz
Itsu
