0 Members and 431 Guests are viewing this topic.
Jeg
Quote from: itsu on March 20, 2016, 09:31:42 AM
Drain/gate screenshots of the new layout, as mentioned, they look similar as the old layout ones.
Great work. Your gates are very clean! Like with not any mosfet connected! At the end, every inch of wire counts on parasitic creation.
itsu
Triggered by a recent link from verpies about measuring the ESR of a capacitor, see this EEVBLOG video:  https://www.youtube.com/watch?v=BcJ6UdDx1vg
i wanted to investigate if i could use my spectrum analyzer with tracking generator to plot the ESR (Equivalent Series Resistance) of a capacitor.
The below video shows that it is possible and what the effect is when paralleling severall different value capacitors.
These are non-polarised capacitors, and i will do the same for electrolytic capacitors later.
Perhaps usefull to keep in mind when trying to silence an oscillating circuit.
Video here:  https://www.youtube.com/watch?v=233S3BdAL9Q
Regards Itsu
Void
Quote from: Hoppy on March 20, 2016, 01:30:32 PM
I've posted a couple of times in the past about how thin wires could have both handled the load and taken through the crimp and into the ground with nothing visible externally, even by close visual inspection.  I'm sure any competent test & inspection team would have removed the crimp had they been allowed to do so so and would have filmed the process. There is no video evidence that this was done.
Hi Hoppy. Ha ha. I won't say it is  not possible, but it seems to me someone would have to be
pretty careless or naive to not take a close look at the ground lug to check for extra wires there.
Anything is possible however. I guess Kapanadze could have had mice running on a mouse wheel
connected to an alternator inside an enclosed box inside the aquarium as well. They would have to be
pretty strong mice however. ;D  Hee hee.
GeoFusion
Quote from: magpwr on March 18, 2016, 09:46:42 AM
For the rest of you still playing with kiddy voltage like 24volts or less for kacher just forget it.
Geofusion did got somewhere around 32kv but looking at the video he did cheated on the kacher.He created extra long tesla coil to generate high voltage but it's definately no where near 1.7Mhz.
By doing that he was able to run at voltage around 12 or 24volts likely.
Hi magpwr and All
Well input voltage is something to think about, I want to say is when you increase input voltage of Kacher ( tesla coil )
You will increase also output load while at resonance.
There is no other reason why to increase your HV pulse input to higher voltages,
24Volts dc on a simple kacher.
I have shown on some of my recordings,
About my long kacher in my vids,  I have Shorten the Secondary  to half of the size of grenade and there was better results.
It's because of this change, I got the particular Ibrahim effect which is awesome.
which was not recorded yet I repeat!
If ppl would to be thinking me cheating because of using long kacher for better output,
that would be a waste of time thinking that. :) there is a balance, search for it.
Why won't no one continue on what I was busy with, Scared? Fear to try out?
We are already playing with fire, So you continue with that road.  :-\
I have shown simplicity and ppl could continue experimenting with it . It will lead you to success in another way.
What ppl need to understand is how these freqs are mixed together. Let it go in Phase together.
I might be showing the most Primitive way using a Toroid " mediator " let it bind within the same field and out.
to mediate this to work. This is as reall as it can get.
Ruslan and Akula or Kapanadze have done this with same concept but different approach.
How this manifestation starts to work within the grenade or any other Cap-Coil is essential to know.
Cheerz~
NickZ
Quote from: itsu on March 20, 2016, 11:47:08 AM
Hi Nick,
Not sure why you want to know all this, as its now just a push/pull driven transfomer, but here it goes:
it can light any or all of the 9 100W bulbs plus the 40W bulb, but the more bulbs i add, the lower the resulting DC voltage and thus light becomes.
With 9 100W bulbs and the 40W bulb connected, the 24V battery input is 7.5A (180W) and this is divided over all 10 bulbs (glowing only).
In this condition the MOSFETs (uncooled still) temperature rises to about 37°C each, the FWBR diodes stay cold (22°C).
I won't be using a kacher, so i am looking into using some other way of "disrupting pulses", but i am not there yet.
I checked on the 40W bulb when running alone (so without other bulbs or the 24V PS), there is 227V DC on it at 136mA which calculates to 30W  (confirmed by my scope math function), so it runs at ¾.
I cannot comment on your kacher transistor, but 24v * 2A = 48W which can heat up a lot of things.
If it is rated for 1500V, it should be able to handle the 227V DC or so from the 28T / grenade, but you should keep an eye on the current, so good cooling is a must.
In this simple setup i have now, i do not expect to get more wattage out then the 24V * 7.5A = 180W i put in, why should it?
Itsu
   Thanks for your answers, they are important to me. I realize that you are just using the induction circuits without the HV attached.
   It's more for a comparison, for myself,  to what a simple Mazilli/yoke/grenade set up can do. While on the same or less voltage, and going to the same IRFP260N mosfet. As it can light 650w, worth of incandescent on just 12v 4.5 amp battery. Although I don't know how much it was drawing. But, it was providing a very usable although unknown lumin levels.  It's the lumins that interest me. Not so much about input/output readings, but the lumin levels that are available from each different circuit, instead.
   Connecting the Kacher to the "mediator" coil, for added gain is still on my to do list. Hopefully without everything going up in smoke.
   Still waiting for Geo to get his rid going, again, also.  Nice to hear that he was able to shorten his Kacher secondary, and still maintain a decent output. Once he makes a video of it running I'll see what frequency it's running at. Previously it was running at around 10khz.
   Itsu, it makes me wonder why you are only drawing 180w, from a 560w PS. To light the 950w worth of bulbs.
