joaouchoa and 232 Guests are viewing this topic.
verpies
Quote from: skywalker66 on March 26, 2016, 04:06:37 PM
Yes, spacing between turns is the diameter of wire, because it was bifilar wounded at first, then removed one coil and remained like in photo.
You sure that plastic tape is so harmful for coil? because akula and ruslan have also their kacer wrapped in plastic tape and seems to have no issue with that.
The plastic tube which coil are winded on have not a similar influence on coil Q factor? it is from plastic also.
As a fact I have a layer of plastic tape underneath coil also for turns not to slip and stay in place. It is also harmful ?
Yes, all high-k dielectrics are detrimental to the Q, even the PP pipe.  The best Q is an air coil with minimal scaffolding made out of plastic rods.
Just because Akula and Ruslan can get away with lowered Q does not mean that you can.  Your other components might not be  comparable to theirs and you do not want the lowered Q to be the proverbial straw that broke the camel's back.
nelsonrochaa
Quote from: forest on March 27, 2016, 12:10:43 PM
Nelson
Can you explain your setup by drawing a picture ?
Hi Forest,
I will not share any detail about work i develop for know reasons , but what i already, share last months  is important to make people for instant reflect a bit ... the people that want reflect :)
cheers
nelsonrochaa
Quote from: Hoppy on March 27, 2016, 01:47:08 PM
If he does that, he will have to show the generator that creates both magnetic and electric fields.
If he does that ....      yes because you already know that i will not show details , in that point you are really clever ;) lol     ,  like the endurance you show every time when you try to find on circuits something to say that is fake . you are really a clever person .....
verpies
Quote from: NickZ on March 26, 2016, 04:25:08 PM
  Did you read the suggested information. You'll probably find the answer there. But, you're assuming that electric meters will read the frequency of Tesla's Aether streams.
I read it.
I am not assuming anything.  I base my statements on measurements I have made on working "Tesla Coils".
The HV RF is picked up just fine by capacitive probe connected to a scope at significant distances.  I wouldn't dare to venture with my scope any closer.  Itsu probably understands why...
Or, are at different frequency altogether, with no current going anywhere, but, having high voltage.
The spark-gap discharges and the streamers from "Tesla Coils" exhibit all the properties of  electric current in magnetic field between two magnets.  See below:
verpies
Quote from: skywalker66 on March 26, 2016, 08:07:09 PM
That coil is intended as part of Ruslan device - kacher coil. Indeed that kacer wire length have 1/2 length of the grenade. It look longer because is spaced - it has 20.7cm.
Grenade wire length = 38.8M , house electric wire, multi stranded, cross-section 2.5mm2
Kacer wire length = 19.4M, 0.88mm diameter;
"I was wondering what your logic might be behind it ?"  No logic yet.  :)
If there is any logic to be found, it will be in relation to the wavelength .
