0 Members and 385 Guests are viewing this topic.
forest
Quote from: nelsonrochaa on March 27, 2016, 04:08:06 PM
Hi Forest,
I will not share any detail about work i develop for know reasons , but what i already, share last months  is important to make people for instant reflect a bit ... the people that want reflect :)
cheers
Can you post me PM with ONLY explaining what you already said , using a picture ? I can for example imagine a setup when the coil is attached to the center tap between two primary coils , thus acting as antenna (or extra coil as you wish)
Anyway, any bit of info is highly appreciated...
verpies
Quote from: Dog-One on March 27, 2016, 01:35:16 AM
Verpies will correct me if I'm wrong here.  You want the lowest dielectric material between the conductors as possible, with air being about as good as you can get.
I am not going to correct you.
I am only going to add, that there is also an optimal diameter to length ratio of these High Impedance and ?High-Q coils.  Read this for details.
skywalker66
Quote from: verpies on March 27, 2016, 04:05:42 PM
Yes, all high-k dielectrics are detrimental to the Q, even the PP pipe.  The best Q is an air coil with minimal scaffolding made out of plastic rods.
Just because Akula and Ruslan can get away with lowered Q does not mean that you can.  Your other components might not be  comparable to theirs and you do not want the lowered Q to be the proverbial straw that broke the camel's back.
Thanks for answer.
Oh man then I messed up...
Next coil I made will be silver coated wire, air cored but immersed into a vacuum chamber.   :)
AlienGrey
Quote from: skywalker66 on March 27, 2016, 04:54:47 PM
Thanks for answer.
ha ha silver wire, struth that will be expensive ! but if you put it in water on it's day off and you pulse it with 7.83 hz you could make your own collide silver, it's a rich mans type of nanoparticle penicillin, look it up it can kill most crap the yanks invent over time ;) you can do the same with gold if you have arthritis. A bit of usless info for you. ;)
verpies
If you'd like to play this way, the vacuum chamber tank would have to be huge compared to the size of the coil in order not to introduce any losses in its proximity.
The wire should be silver, all right, but not a solid wire.  Instead, i should be a fine Litz wire.
This article refers to it as "current pushing" or "current bunching" but EEs often refer to it as the "skin effect" and "proximity effect".
