0 Members and 184 Guests are viewing this topic.
MenofFather
Quote from: Void on April 03, 2016, 09:36:13 AM
Hi MenofFather. Yes, I think it is good to keep in mind that one of Ruslan's early replications of Akula's
device was using only a simple kacher driver circuit for the tesla coil, and the power supply output was only 12 VDC.
Ruslan only switched to a 24 volt power supply a bit later, if I recall correctly. So, if Ruslan's video demonstrations
were not faked, then we should be able to get a basic version of this setup to self run with just a simple kacher driver
and a 12 volt power supply for looping.
The frequency that the tesla coil resonates at is one possible variable that may be important, but maybe the quality of
the earth ground connection is also very important. However, Ruslan showed his early simple kacher driven setup working in
his living room with just a fairly short ground wire going over to his radiator. The ground wire was not all that thick as well.
I have noticed that GeoFusion's earth ground connection seems to have a fair bit more impact on his circuit than
the earth ground I have been testing with. Maybe there is something special about the earth ground quality at certain locations,
and if you don't happen to be living somewhere in the world where earth ground has this special quality you may
not see much in the way of results. I do get some increase in output when I connect earth ground to my grenade output,
but the effect seems to be smaller than what GeoFusion is getting, for example. I have been testing
with a ground wire going over to a cold water pipe in my washroom. That should be about as good as connecting a ground
wire to a radiator, but maybe because a radiator has more metal mass and heavier pipes running through the building, it
is better. I don't know. :) Then we also had Akula show his first self runner device self-running in his yard with no earth ground
connection to the device at all.  :o :) ;D
Here also no ground https://www.youtube.com/watch?v=a3mCdYomu-0 and he using kacher. He get up to 4 kilowats from 12 volts akumulator. Where curent from it must be 333 amperes. With that curent 45 amh akumulator must disharge in 8 minutes. He say, that divice running (maybe with 2 Kw, not 4) on that akumulator day, then need recharge.
MenofFather
Quote from: NickZ on April 03, 2016, 09:26:56 PM
  Perhaps MenofFather can tell me, what he is saying about the device linked below. Some of us have already seen it.
I'm wondering if it does drain the car battery in time, or not? Or the wattage that it draws? Anything, important about it's operation.  In order to be able to run all those things that he's showing in the video.
  This modified Kacher powered device below, if true, is pretty amazing, concerning the amplification effect.
And it's so simple, you'll laugh...
   It would not seam too hard to loop it, with that shown output, as well.
   https://www.youtube.com/watch?v=wd2OFmlTNNc#t=728.076957
He saying, that he buy schematic. Schematic not dificult...
How i Wrote in prievous my message, battery need recharge about after day, maybe 7-18 hours working with 700-2000 kw load, then neeed recharge. In some his video, he showing 4 kilowats how working (fen 2 KW and heater 2 kw).
Jeg
Quote from: T-1000 on April 04, 2016, 05:50:04 AM
Mixing these two together is giving output boost. This how I see effect there.
In my opinion, mixing is what it can be seen from the point of view of the observer. Keep in mind that behind this might be an other action that makes the amplification which can not be observed through our oscilloscopes, and might not be just mixing.
NickZ
If you studied diagram I shared a while ago, it tells you there are two loops:
1) Inductive loop for magnetizing grenade coil from push-pull.
2) Capacitive loop for charging up capacitive element of the grenade coil in electrostatic way from the Tesla coil. Also that initiates electrostatic pump to the ground over grenade coil which make additional resonant electrons flow in grenade coil.
Mixing these two together is giving output boost. This how I see effect there. To create high potential electric field it does not cost you, only losses in driving Tesla coil are accounted. So the output boost is for free to exploit. :)
   T-1000:  Two loops? Or, two different circuits, not loops?
As loops refers normally to a feed-back loop when the word loop is mentioned.
Yet, the number (2, capacitive loop) is still working by inductance. Not capacitively.  How is this NOT working inductively then? As it seams like the Kacher circuit is working by inductance like a normal Kacher circuits. Primary to secondary by inductive coupleling? OR, is it just the Kacher's output that is capacitively acting on the grenade's inductor coil.  Or what?
Is there a cancellation of inductance in the system in general, or not? As even the grenade coil has induction cancellation if those counter wound turns are actually working for that purpose, such as the schematics are showing.
   MenofFather: Thanks for your reply.  So, we still need to find out how this is all possible for a simple Kacher circuit to run all those things for hours. Very important thing to know, as a first step towards the direction of self running.
   He bought the circuit?  Ok, then. Anyway to know from where or from who came this secret circuit?
NickZ
Quote from: Jeg on April 04, 2016, 07:43:48 AM
    You mean like how or where the additional Aether is being pulled into the system?  Which can't be seen or measured. Or, just what this "other action" may be.
