0 Members and 140 Guests are viewing this topic.
T-1000
Quote from: NickZ on May 14, 2013, 01:33:56 PM
  T-1000:
   Ok, thanks for the information, and links.
  What is needed are the actual specs, in order to replicate this, as to how to go about it.
The problem with all replications is - everyone assemble circuits without understanding how it should work.  Obviosly none of that type are in science books so I cannot refer to anything usefull in classic science. This is why I spent reasonable amount of time trying to explain stuff so you can design own circuit when you know exactly which component should achieve what. Maybe I am not good teacher, I do not know, it is not my speciality.. :) Please try to understand what you need to achieve first then technical design details will be yours without too much questions how to do it.
To summarise, devices in this thread have common thing (except from tiger2007 latest diagram):
They all use strong magnetic field created by resonance in series and with help of additional coil this magnetic field is modulated creating induction on output coil(s). The entire circuit of this type have few resonances on single frequency with resulting output in resonance too.
In regards to akula as far as I know he is not ready to be slammed by entire world so needs some break. Eventually, I hope, he will share all details on his expierence in FE field.
If you choose to get working circuit based on tiger2007 diagram you should study first how secondary emiision-like effect is created on few milimeters depth plexiglass between copper and alluminium plates which are between two magnets for increased electrons emmision. This is key element in Testatika and also key power source element in diagram I posted here.
Cheers!
NickZ
  I understand the concept, BUT, ideas are not what is needed. One can build anything, from a kit, or whatever, and make it work, without having any idea of how it works. The how it works, is not what is needed.
   I repeat,  a working diagram, clear pictures, and a proven replicated device is what we need, now.
Not more ideas. We already have 1000 + pages of ideas, and no working device.
  I am not pressing you, or anyone else to provide the actual things that are needed. But, it's more than likely that no one is going to replicate the Akula 0083 device by guessing at how to do it, or by trial and error.
  This is like trying to find a radio station, without a working radio.
T-1000
@NickZ
There is no actual diagram of akula0083 device because he did not share that. Also it was not his idea how to create strong magnetic field and how to modulate it without affecting power source much - which is quite good hint if you are really stubborn to get replication/own version. I understand frustation just this is how it is.
My advice on this: try to follow akula0083 steps and get resonance in series first like in induction oven. Then try to modulate that field so coils winded on top would have changing magnetic field on different axis. Then see how much output you can get. This is at least some starting point...
NickZ
  T-1000:
   Thank you for your help, and being honest about all this.  I know that you have been at this a long time, as well as some others. And that,  it is not easy...
   I will continue to do what I can. As I mentioned, I'm good at finding my way in the dark. But, even a small light at the end of the dark tunnel would really help.
   I feel that the reason this works, is the same reason that we can obtain electricity by moving a magnet next to a coil. Except that what is moving, in this case, is a "field", instead of the coil or magnet.
I may be completely wrong, but that is what I'm going on.
   Thanks, again.
                                NickZ
verpies
Quote from: NickZ on May 14, 2013, 08:00:47 PM
In my opinion it is a shot in the dark to try to replicate such devices without:
1) Scope shots of current and voltage at all significant points.
2) Complete electronic schematic diagram
3) Part & material specifications (especially ferrites)
4) Exact physical dimensions
5) Spectrograms / Smith charts of all reactive components.
Last point is the least important. I would gladly resign from having a video if I had pt.1.
Only Wesley and his team provided pt.1 for the Yoke device.  That was exceptional by itself.
