0 Members and 663 Guests are viewing this topic.
Tomtech29
Quote from: GeoFusion on April 25, 2016, 10:53:44 AM
Hi Void
Yes, it changes the tuning completely.
First part of the vid is without the ground connected,
having to show how the synchronization works the reason why it's behaving like that :).
after reaching second part of video you see I have ground connected, where you can see
it will keep them lit and might say fully bright. 100W halogen and 25W microwave bulb.
If I should disconnect earth, there is no light! maybe very weak burn on filament.
They become very hot when fully lit! you feel the heat coming out of it, its different from back then.
yes without kacher it's pulling about 1 amp or less. pushpull.
With kacher it can reach up till 2.5amps on meter. 24V PSU.
When waving hand, I see mili amps movement on meter when full brightness at output.
Both test were with Mains, without ground and with.
Further test will be done with 24V car battery.
HI.All
I support the development of research on improving this device but you must realize that your system is excited by high field "ionization/ radiant" - At radiators aluminum
which directly carrier HV. on (IC)78XX and the control system!
So voltage jumps across the low-voltage system the system becomes unstable!
example is like a hand observed energies of the earth system is suppressed, or if you prefer shielded.
- categorically is too close!
- system is not electrically isolated
- measurement errors
- and strengthen the whole is nothing more than higher rated voltage of normal operation of the filament.
- elongated secondary coil Tesla resulted in high voltage :P and that's it...
- sooner flowers wither as you light the 300W. or I get sick from such a strong field
and for the curious a look how it is connected TL494 to IR211X Akula system inverted  IC 79XX ?
I'll bet I'm right  would like someone to challenge?
(I play cards on the table and tell you that it is no longer seen)
or friend me something snaps?
thanks for the video.
Void
Quote from: Grumage on April 25, 2016, 03:04:09 PM
Dear Void.
Aye.... That's the one, pretty impressive!! Note there was no change to input energy upon lamp removal.
A simple starter perhaps?   ;)
Cheers Grum.
Hi Grum. Yes, it seems to have some potential. In the least he showed how the earth ground can make
a very noticeable difference in HV AC circuits. I have seen the same sort of earth ground effect several
years ago when testing with HV spark gap circuits. I could connect the earth ground either before the primary or
somewhere on the secondary/load part of the circuit and it made a very noticeable difference to the way
the circuit performed, making the circuit much more energetic. However, in my case, even though I was getting that
same sort of earth ground increase effect with HV spark gap driver circuits, the input current draw from the battery increased
when connecting the earth ground into the circuit. I was not able to see any apparent OU effect in those experiments.
Jeg
Hi Void, all
Has anyone here ever tried to shield his Katcher coil with a grounded metal mess? Does this limit katcher's affection to the surrounding electronics?
verpies
Quote from: Jeg on April 26, 2016, 03:25:38 AM
...grounded metal mesh? Does this limit Kacher's affection to the surrounding electronics?
It should
MenofFather
One man replicated Ruslan divice, and he get selfrunning with 2 kw power, how he say.
For him need suport. Who want help him with money for his work, here is his bank number and name of bank
4038 9801 9772 6848 Банк авангард (Bank avangard).
I think, if people him support with money, then biger chance that he share information, how build what divice.
He don´t want for free share information how build this divice.
