0 Members and 854 Guests are viewing this topic.
GeoFusion
Hi guyz :)
Well I uploaded a new Vid, wanted to show the comparison with what Ruslan Device is showing
and what I have on my setup When effect is in play :).
Geofusion New Mediator & effect 4
https://www.youtube.com/watch?v=XhblojKdU4Y
Ruslan Vid, Turning on and off kacher
https://www.youtube.com/watch?v=zEBLgIbxP3o&feature=youtu.be&t=1m21s
Enjoy :)
                      Cheerz!~
itsu
First quick test with a (shorted) RG58 coax cable wrapped (27 turns on a 9cm former) around the inductor / part of grenade.
In the video i mention that the peak value has increased somewhat compared to the 50 Ohm resistor as the scope shows initially about 1.8KV, but thats because
it now also measures the reflected reversed signal.
So the positive peak is still about 1.5KV like it was with the 50 Ohm resistor.
The reflected reversed peak is seen after a delay of 80ns pointing to a coax length of 8 meters (0.66 velocity factor).
Screenshot below shows the signal
When scoping the grenade output (unloaded) it shows a noisy signal with a peak of 70V, see video (2th part).
The inductor/capacitor series LC output shows a similar signal as the grenade, so we have some inductive/capactive coupling from coax to inductor/grenade.
Video here: https://www.youtube.com/watch?v=K4Fj7O0lgbk&feature=youtu.be
Itsu
Void
@Geo:
Nice video. I am not clear where you have the 'mediator' coil connected to which is wound on the other yoke core.
What are the two wires on your mediator coil connected to?
I hope you were wearing some shoes when making this video. :)
@Itsu:
Your new nano-pulser seems to be working really well.
I would guess you may be getting a higher peak voltage when connecting to the coax
winding because the nanopulser is seeing a somewhat reactive load at a different impedance.
Nice job guys...
verpies
Quote from: itsu on April 29, 2016, 04:40:50 PM
That's to be expected.  80ns is the round-trip time.  Multiple reflections of progressively lower amplitude should follow the first reflected pulse, because the nanopulser apparently has lower than 50Ω output impedance and it re-reflects the reflected pulse coming back from the far end ...and they do.
What is the actual length of the coax?
It would be nice to see non-inverted reflections from an open-ended coax, too.
That is a little weird because there are quiet periods between the reflected pulses in the coax but no quiet periods in the grenade output, so it is not an exact copy of that signal (thus not only a direct coupling) so something else is going on, too.
Also, the 60Vp-p inductive/capactive coupling from a shorted coax to inductor/grenade is weird in itself.  I'd like to read a physical explanation of that.  I hope I will not read "leaky coax" or "scalar waves" ...err "pseudoscalar waves" ;)
verpies
@Itsu
At the risk of being yelled at by Nick and other Aether aficionados, I'd like to suggest that you put a fuel rod (an iron or copper pipe/rod) inside the grenade and run some current ALONG it, while bringing large permanent magnets nearby, because I think that there might be something similar to the diagram below where your nanopulser and coax can take the place of the the 500VAC RF amplifier.
Support structure and low reluctance path as well as the 0.5T polarizing coil are too much work so if you skip them you can hope that a strong magnet can make up for their absence.
You can try that after all else fails to make any extra energy.
