0 Members and 854 Guests are viewing this topic.
T-1000
Quote from: verpies on April 29, 2016, 06:06:01 PM
@Itsu
At the risk of being yelled at by Nick and other Aether aficionados, I'd like to suggest that you put a fuel rod (an iron or copper pipe/rod) inside the grenade and run some current ALONG it, while bringing large permanent magnets nearby, because I think that there might be something similar to the diagram below where your nanopulser and coax can take the place of the the 500VAC RF amplifier.
Support structure and low reluctance path are too much work so if you skip them you can hope that a strong magnet can make up for its absence and the 0.5T polarizing coil.
From Aether to NMR is not the best case either unless proven by the actual test on Kapanadze style device.
I could also throw in theory about energy from standing wave which contain magnetic component in one side and electric field component in another but won't claim until will have experimental device self-running on the table.
Will see on facts over time what exactly is going on there.. :)
Cheers!
verpies
T-1000
Quote from: verpies on April 29, 2016, 06:24:33 PM
Arunas!
Must have you used the scary N word !?
:) This what device in your picture attachment was meant for.
apecore
Quote from: d3x0r on April 29, 2016, 01:13:02 AM
@itsu if this continues very far, should start another thread.. BUT.
So, just for grins, one could at 15khz put a tesla primary to the impulse generator? and run it at low hertz... wasn't it very low frequencies tesla said he saw aura around coil?  (Not bright sparks, but more ambient... aura)
secondary should be highly insulated??  At 1.5kv input you're already going to be sparking if it was a 1:1 ratio?
D3xor,
You mean putting the 15khz puls by the impulsgenerator at the tesla primairy? Instead of generating the nanopuls separatly?
Guys,
Just for clarification ;D
Isn' t this a good remark instead in case off all the effort itsu is doing at the nano pulsing?
Not saying that it  won't work what Itsu is doing...but we must always open for new approaches.
So what is the opinion of the well known hero member in this?
Can someone give his reasson why this it is not worth experimenting?
Itsu,.. what is your opinion about this idea?
Is the impulspower as configured additional needed?
wattsup
@itsu shows the outer coax center solid line and outer shield are connected together so the outer shield now becomes part of the coupled line.
There is no general diagram to follow but if I understood @itsu's two videos, the inside coil of the grenade is the one being pulsed while the outer is the coupled output. There are always two sides to a pulsed coil, one side that is permanently connected (PC) and the side being pulsed (BP). What is not evident is which of the two inner coil lines is being pulsed, the center line or the outer shield. I would hope it is the outer shield being pulsed since it is closer to the outer coil being induced.
But at pulse on, that polarity enters the pulsed coil for a small period of time, which induces the first spike rise in the outer coil. When the pulse is off (for a longer period of time in one cycle) the pulsed coils PC side reclaims the polarity introduced by the BP at pulse on and the outer coax coil sees this additional change as the trailing lines on the scope. If you scope the pulsed coil you should see a very nice negative flyback (if the positive is pulsed) or a positive flyback (if the negative is pulsed).
The many waves in the off time is the result of having connected the two conductors of the outer induced coil , center and shield together so you have induced then cancelled conditions. I would open that connection and put a load there instead to see that output would have less cancellation.
Also it would be very advantageous if the center pulsed coax was in series with a good length of wire on an air core set beside that coax coil to increase that flyback. The length of wire on that added air core coil should be at least the length of the inner coax being pulsed. It should be in series with the PC side. I think this is why many of these devices have these air coils added as what I call Slave Coils. They permit the totality of the pulsed coil to change instead of only half of the coil.
wattsup
