0 Members and 2079 Guests are viewing this topic.
SolarLab
F. Y. I.
From the video: "Kapanadze - schemes, photo installations 31/03/14."
This video is of little value -BUT- the comments offered by Ruslan Kulabuhov (who has successfully designed, developed and demonstrated a CE/FE Generator) are very interesting and quite instructive! See below...
https://www.youtube.com/watch?v=1iPz4qHJV4w&google_comment_id=z12kgxxz3sy2vlb3w223vbsyzq2mit0fn
Video Published on Mar 31, 2014 on youtube
Video author caption comment: "diagrams and photos of different settings Kapanadze collected over 4 years with me."
Poster's COMMENTS/NOTES ((machine translated from Russian to English; difficult at best, since many Russian technical "words" only have a "practical hands-on <lengthly and sophisticated> meaning;" for e.g. OEDS))
... Ruslan KULABUHOV's COMMENTS
============ Quotes from Ruslan linked comments: ===========
Ruslan Kulabuhov 9 months ago LINKED COMMENT
For those who are not groping in the art, and even more so in this one. Do not write garbage! If there is no spark, is not talking about no operating system. Idiots! The spark arrester is not for the work process of the system, and for Goshen excess voltage amplitude to avoid breakdown of the coil. Commentator video did not understand anything in this technique, and then manages to ascribe different snowstorm.
3
Ruslan Kulabuhov
Ruslan Kulabuhov9 months ago
So I will explain a little bit how these all systems. And the principle is simple - OEDS and its use. Bifilar coil is a reactor to avoid inductive coupling interference in workflow and load at the same time, the capacitive charge of explosives in the transformer. Soon there will be a video with a yield of 50 Hz. As with all Akulina system clearly and frankly very dreary. Not the stability and profitability of the system makes it difficult and not practical. Everything is much easier than it looked. My advice, stop by spark coils. This does not work ! Spark arrestor for Goshen surplus and ringing coil. Everything is simple here. Main including the brain. Hint: Do Nikola Tesla was not diodes and transistors, as well as radio tubes. He did everything in the breakers. Then, starting in the coil 50 Hz AC, your BB coil must generate a pulse of 5 kHz !!! This is exactly verified and tested! Charges embarks on a copper tube around the bifilar coil, charging her. Anyone interested, please be patient. I finish the device and will lay out the scheme. I'm afraid that if Kapanadze will be repeated every 5 s radio amateur. It is good and ...
9
Ruslan Kulabuhov
Ruslan Kulabuhov2 months ago
Where have you been listening to fairy tales? The parameters are not changed. At least I have worked 2 months without interruption. Power 600 watts. 4 kilowatts felt no more than 5 days, I do not know
Individual Ruslan comments: (latest first; [LIFO <Last In First Out> order]; earlier last. From youtube's "Newest first.")
Coil any current delays in yourself. OEDS - the result of high emissions. Current late. And also in the coil there is a cold current. That is what we want !!! Now you have to add charges and push current and contour. This is what makes BB !!!!!!!! Over the coil is wound coil of thick wire. This capacitor plates - ionizer. When filing for her short pulses, the charges will flow at high speed currents pushing stuck in the coil when OEDS. formed CE
----------------- (comment from another participant) ----
Ruslan good time! You can shoot video of the final setting, the time when the system starts to work and how to behave with the current induktsionke (whatever his shakes and instant hook)? Have you recently had a good video, 'Experiment 1' -there you showed how the lamp lights when the Tesla !, lacks it just these waveforms! What turns capacitance between induktsionkoy and toroid Tesla ???
---------------- (back to Ruslan's comments) ----
The essence of the momentum that nobody understands! The coil has the ability to delay the current. It is necessary to push it to the load. So it is necessary to add a charge to do this. Question! How ? Pulses - a little expensive way to drive a bunch of electrons at the right time. Again ... Classic current here is not working. then run cold currents origin or induced currents of the coil itself. Here we use them!
Not certainly in that way ! The system uses the energy of self - acceleration. Beyond a single effect is. You just have to understand, from where he was. You nick name Free Energy, and you write this :) Tu just need to understand the essence of the processes.
Waveforms not help you! This effect devices can not see. There will need to find the stupid instinct, as it were, when and what should happen.
You just do not realize that this other current and other currents of nature. Why do you not, because you're not doing the stupid and do not understand the essence of the process. You do not even know why you need a boost and that it creates in the medium. Fucking you and sparkle even the shit. If you still do not understand from where OEDS and the impact on the environment has a coil and that of the currents running in it when closed core already. Where you climb then? I 200 000 reiterated that the current in the system is not a classic, and so cold the voltage and current will not be connected to hot. They are different ! But you do not understand. As pulses are forbidden for you everywhere, and there is no sense. Because you do not understand their nature. It's past !!! And no one will do anything until you understand that there is an environment and its impact, as well as the magnetic field, which clearly repeats the operation of the primary field. These are different currents on the structure. But they do the same job as the usual classic current. And even better ...! It is the nature of currents and talked about this Nikola Tesla.
~~~~~~~~ {poster's injected - this thread only comment:} ~~~~~~~~~~~~
From the beginning, again consider:
Quote; "The electrophorus is a wonderful device that was invented by
Alessandro Volta in 1775. He called it the elettrofore perpetuo. It seemed to an almost endless source of charge." (reference: AP Physics - Static Electricity).
This "transfer of charge" involves no apparent "current" - a.k.a. "cold current" or "cold electricity" or, from more modern theory (incorrectly re-written) Maxwell's equations, "displacement current."
{You actually can get 'here' from 'there' but the modern Physics {BS} makes it difficult since Maxwell's Equations now involve no [engineering] mathematical logic. See Prof. Meyl for the corrections, explanation, and path forward [Dr. Constantine Meyl also provides great insight towards explaining Longitudinal or Scalar Waves].} Anyway, back to the topic...
------------ (returning to Ruslan's comments) ------
I'm tired of repeating! Do you read carefully, or what? Once again I say. Currents not classical and adjustment means will not help in this system. Deal with current and how to get them. One of Tesla's enough!
I've already told all!
I can say one thing! Current voltage is subject. The magnetic field is readily converted to the current and inversely. The pulses are then not entirely and. But the fact that they delayut- important.
pulses form a standing wave. Voltage antinode or at the end. duration for each kabelraznaya
I have 200 times repeated that to which the wind, it is necessary to understand the process! For free you it will not collect and customize.
Know what is necessary to AC!
And what's the point to drive the momentum? There's no pulse and a whole pack of them. This time ... The multiplicity of frequencies is very important. Without this, nothing will happen. Necessary to drive current, and no voltage in the circuit. In other words, do the current resonance frequency and multiplicity chase in the half-wave pulses Tesla. You get all that is necessary. During assembly of the basics, take Dali scheme. There's just the current resonance.
Again begins! And here the impulses? It is necessary to catch the effect of the coil with a current rather than pulses.
You write nonsense! Ring already measures the current in the wire.
For those who are not groping in the art, and even more so in this one. Do not write garbage! If there is no spark, is not talking about no operating system. Idiots! The spark arrester is not for the work process of the system, and for Goshen excess voltage amplitude to avoid breakdown of the coil. Commentator video nothing
Note: Just for the record; bare in mind that a "Spark Gap" has a variety of applications. It CAN be used as a fast High Voltage switch AS-WELL-AS a High Voltage protection device. However, in the Kapadnadze apparatus, I believe Ruslan is correct in observing that here the gap is a protection mechanism. Without a detailed schematic or theory of operation one cannot be sure of course!
FIN
T-1000
Quote from: N20Wolf on May 11, 2016, 11:39:26 AM
Hello! The new scheme generator from Sergey Alekseev. Scheme: https://yadi.sk/i/rYuY-kMArdm3D Download This Archive: https://yadi.sk/d/rLAAv4xOrdhsv
That is another circuit with the yoke/isolation transformer output straight to Tesla coil...
verpies
Quote from: Hoppy on May 11, 2016, 03:27:14 AM
The video would need to show the ammeter visible throughout the demonstration.
Because if the Kacher causes an increased input current, then the increased heating of the iron would not be so "huge" anymore.
Dog-One
Quote from: verpies on May 11, 2016, 01:49:23 PM
Red hot iron in 10 to 15 seconds?   He would need to be suddenly pulling 50 amps to do this by conventional means.
I have my suspicions when he activates his Kacher, there's more going on inside that plastic tube than meets the eye.
I say this because I tried a similar test using 24 volts at 5 amps and I could indeed warm-up a steel screw driver, but
nowhere near glowing red hot.  I was at least an order of magnitude away from that, even fully tuned.
Hopefully Geo will publish a video demonstration to clear this up.  If it's doing what he says it is, how it's happening
is of great significance.  There must be one heck of a magnetic field concentrated within that 50mm plastic tube.
M@
AlienGrey
Quote from: Dog-One on May 11, 2016, 03:56:29 PM
M@
can you get the same effect if the microwave door is left open ?
