0 Members and 122 Guests are viewing this topic.
Tomtech29
Quote from: AlienGrey on May 13, 2016, 11:31:02 AM
This is the old device already, there is a new layout of the PCB has anyone got a copy of the underside view and component layout schematic the one i found is not very viewable and out of focus,,, if someone can find a good copy I can relay it out and shove it back out one here if any ones interested.
AG
Hi.
This is a strange transformer called a Tesla regulator
Your PCB looks like this ?
AlienGrey
no like this ! but if you use it, it'sat your own risk, i have not built it yet ! but be my guest it's better than nothing but check it as you go along.
itsu
I have changed the nano-pulser to be fed by the yoke (mediator) instead of the 24V battery stack.
So only thing fed by the 24V battery stack is the push-pull driver driving the yoke (mediator).
This yoke has the 3 turn secondary for the series LC circuit and the modified 28 turn secondary (only 14 turns left) to drive (after rectification to 24V dc) the nano-pulser.
The parallel LC circuit is removed for the time being, so we have the Grenade (layers 1,2 CW, layers 3,4 and 5,6 CCW) 38m length, on the exposed 1,2 layers we have the
shorted coax wound, 6m length, and on top of that we have the inductor in 3 layers bifilar wound with 19m length.
The coax cable layer between the grenade and inductor has severely hampered the transfer between them as we only have about 76Vpp on the grenade output which
after rectification yields about 46VDC going to the single 100W (220V) bulb which dimly glows at resonance.
Activating the nano-pulser only further dims this 46VDC somewhat for now.
Only ground attached is to the 6th layer return wire of the grenade.
Video here:   https://www.youtube.com/watch?v=yDZZUSZkG4Y&feature=youtu.be
Further testing to be done, still thinking of adding the parallel LC circuit underneath the grenade, and/or adding a copper/alu sheet around the grenade.
Itsu
T-1000
Itsu,
Just seen your video and there are two things which need to be solved. The output of grenade have to be sinus wave and that happen after resonant series lc on inductor. That go directly to load after, no secondary yoke connection in series. The second thing on 6:03 of video scope shot is, the oscillation on high frequency on the sides of square wave. It is the frequency for nanosecond pulser to form it's peaks.
Hope it helps.
Cheers!
a.king21
Maybe it's time to have another look at the aquarium 2
https://www.youtube.com/watch?v=0JXFWuwlg-0
This, fater all, what we are trying to imitate.
