0 Members and 162 Guests are viewing this topic.
justawatt
Quote from: PolaczekCebulaczek on June 20, 2016, 04:11:23 PM
Roma is fake,we can clearly see buried wire in garden video coming from earth to load and he wants money from western union,pathetic.but grey switching element conversion tube/motor is one of the 5 devices that i believe worked,i'm not sure about kapanadze/ruslan/akula/vasmus stuff - i gave up on that some time ago but i will now try to rebuild grey stuff and post results,i sounds easier too.
PolaczekCebulaczek ,you mentioned "Roma is fake,we can clearly see buried wire in garden video coming from earth to load".
can you make snapshot from the video where you see it.i have gone through his video i didnt see it.
i am investing lot of time to replicate his device.
Does anyone here knows what E-H antenna
https://www.google.co.in/search?q=E+H+antenna&client=firefox-b-ab&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjy363V6LjNAhXMK48KHfnxBkoQ_AUICCgB&biw=1366&bih=657
Reiyuki
Quote from: PolaczekCebulaczek on June 21, 2016, 01:37:45 AM
this is very interesting,however would it work when coil fields are not opposing? like plates between N S poles? also this DC voltage on plates could be from inducted currents from changing mag fields...so we want to see if thin capacitor will get charged and stay charged after power in coils is off.
If both plates are different metals, you *should* get a potential difference between them, regardless of the direction of magnetic flux.  How much potential and how much current will have to be determined through experiments.  Luckily it's a very simple circuit to build.
Jeg
Quote from: justawatt on June 21, 2016, 05:38:50 AM
See below link, but It could be just a junk.
Quote from: Hoppy on April 04, 2016, 12:23:01 PM
Here are IMO some suspicious shots taken from that new video. Notice how a cable appears to come out of ground close to the battery and continues to a point in front of the fire where it appears to become buried. I think it possible that this cable continued beneath the ground and into the bottom of the fire where it was connected into the cable running back to the device. When the fire was lifted the connections broke away from the fire.
E-H antenna. As its name tells, it is an antenna which receives both EM components. Magnetic and electric fields together.
NickZ
      However,  I can clearly see a cut fallen weed stem, with a branch going off.  Not a wire...
     Unless you think that Poma is an idiot, and wants you to see a wire,  that's not there.  Look again, more closely, next to the battery on the ground.  If that's the wire/weed stem that you mean.
      If Poma's device works, it's worth much more than he is asking for it, or, even for just a true schematic.
    Hoppy started all this fake X-wire BS, and once again he's seeing, what's not there in Poma's self running device.
We've been through this discussion before.
   This talk about fakes of Poma's device(s) is leading you away from the most important device, of all, yes, that one.
   Don't be fooled by what you think is an X-wire, and assume the guy must be an idiot, or something.
   Is there any one actually replicating it?
   In any case,  I think that more and more of these type of device(s) will be forthcoming in the near future.  Time will tell.
Hoppy
Quote from: NickZ on June 21, 2016, 10:57:24 AM
