0 Members and 610 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on August 05, 2016, 09:06:21 PM
  apecore:
  It would be good to show a picture of your set up. Your description is not quite clear to me.
  And, yes, the higher the frequency of the Kacher, you'll start to lose the output. But, finding the best working frequency, is not easy. Normally the Tesla coil will run from about 500kHz, to 2mHz, with the ferrite rod in place with 5 and 4 turns (reversed) on it, and 6 turns of thicker 6mm wire (or copper pipe) as the antenna coil. This will all depend on how long the secondary coil is.
   If your not using the recommended transistor, on the Kacher circuit (2SC5200), you won't get very good result. Also if you don't have a proper 37.5 meter earth ground, you won't see the best output from either of the Kacher or induction circuits.
  Two fingers should be able to reach under the antenna, between it and the inductor. So, the antenna coil with 6 turns on it, should be at least 1/2 to 3/4 inch or so away from the inductor.
  There are many variables, so try to keep to the recommended turns count on the Kacher primary and secondary. Not too long on the secondary, as the main purpose is to sync with the grenade, not to light the bulb. But, you should obtain a minimum of 3mm streamer, from the Kacher's output. As a real weak streamer, like 1 or 2mm, or no streamer just a weak spark, may not be strong enough to do what it has to do.
  So, get your Kacher circuit working right first, connected to a 24v, 10 to 15 amp power supply.  You should be able obtain a 1/2 inch streamer, or so.  But, I also placed ferrite inside of the former tube, as I showed in my last couple of videos.
  You might want to order one of these new 15 amp, higher frequency rectifier boards.
  http://www.ebay.com/itm/600V-15A-Ultrafast-Rectifier-Bridge-Diode-Fast-Recovery-Use-4x-ONSEMI-MUR1560-/172105952964?hash=item2812506ec4:g:cFEAAOSwo6lWFhVv
Hi Nick, could you please explain what you mean by streamer ? ( streamer nothing but a streamer always got her hands in her head oh no!) https://www.youtube.com/watch?v=urMjGAimtRc&list=RDurMjGAimtRc#t=46 ;)
For details on the coil winding go to same tread Page 354 re Ruslan artical. Good luck ;) AG
apecore
Hi guys,
First i like to thank Nickz for his points.
Hereby the link to the video where my first setup is working.
https://youtu.be/VdOR9jvNnag
At this moment i don' t have a 2SC5200 i used a FJP13009.... it can handle 8Amps
Also i see no different streamer length with or without grounding. .(also no Dreamers AG?)
What i also like to try is the tesla setup (i think Ruslan setup)... with only two windings on tesla top and put it inside output coil.
This maybe something to explore after adding inductor coil?
For now is to see or the streamers are getting longer.
So comments till now are welcome.....tomorrow and next week time enough to play on the bench.
NickZ
  apecore:
  Thanks for showing us your set up, up to now.  Nice!
  There are a couples of things that I would do though.
  One thing is to have your Kacher coil primary coil further away from the secondary coil, like about 1/2 to 3/4 inch away, as   there's a reasons for that.
   Your ferrite rod should have 5 turns on one side, and 4 reversed turns on the other side. Even though the second pic below does not show that.
   Your "antenna coil" should be placed on the right side of the grenade coil, yours is on the left side.
   Any ways, it is a Great start.
   Get the right Kacher transistor, they're not expensive, and some tv repair places even have them, which was where I got mine.  Also test ground wire issues. The more the system is in tune the more the ground connection will make a difference, but you have to tune with the ground line connected, to see the effect that it can make.
  I have 37.5 meter of ground line connected to my circuits, and going right into my water well in my back yard.
But, I think that in this video by Ruslan he shows that the ground line at the end is not connected to anything, and it still works that way. Of course everything he's made works, some how.
  https://www.youtube.com/watch?v=ftlBBIvGtB0#t=531.576317
  I would continue building up the system even without the induction circuit in place. You can still build up the 3inch yoke core with it's primary, and two secondary coil windings, and connect your grenade's inductor coil to it, through the in line 0.47uf tuning cap, etz...
  Here's what my 24v version of the 3inch yoke with all the windings on it looked like. Once finished it measured almost 4 inches across. (Picture below).
  It's better not use the smaller yoke cores,  just 3 inch size, or bigger.
   The second picture is of Ruslan's Kacher, at least one version, maybe not the best one. Notice the short secondary coil.
That picture had been uploaded here before, by Hoppy. There are several other versions of his Kachers, as well, like in the clear box top video linked to above.
apecore
Quote from: NickZ on August 07, 2016, 09:00:52 PM
  apecore:
NickZ,
Thank you for reply. I ve followed_up most of your comments.
Hereby the results;
1-I have changed the primairy coil with 6mm2 wire.
2-I do have now the recommended ferrite setup 5/4
3-Antenna is now positioned on the right side and covering L1-L4 of the output coil (same as the inductor)
4-2SC5200,...  i had 4 of them in a box,.... buyed them after your issue months ago..... so also installed.... 2.2k from positief to basis and 10k basis to ground.
The pick-up coil gives some different resonance effects, on the same tesla coil,....  so this is usefull for ideal settings ( i use upperside of the 10 windings 1mm pick-up coil)
Ground wire indeed has influence,....  i have two ground connections one my normal home grounding and second approximately 20meters in the garden 6 feet copper rod 12mm about 10feet deep.
Maybe i will get a issue with the wire connected to this grounding (2.5mm2 solid),...i will findout later....(someone experiendcedwith this?)
Hopefully it works all same as Ruslans device?
Not yet i build the yoke core and connected it even the the tuning cap,...good suggestion i guess.
Tuning has to be 1/50 of the 1.245Mhz i believe,....24.9khz...    I will measure my inductor induction and define the tuning capacity.
You have use a TV Yoke?....  i have also 2 or three different types...i will use the same solid copper 2.5mm2 for the yoke winding...
Yes i have now also a short secundairy there i prefer to position the primairy in the middle of the secundairy.
Attached a picture of the setup with the changes,...... the scope is connected to the output coil and the ground is connected to outputcoil and inductor and the whole system is in resonance at 1.245Mhz with 1Amp feeding to the Kacher.
AlienGrey
It looks like you have used 1.5 household  cable (solid conductor) the problem with that is it's not pure copper and it gets hot and melts the plastic tube and it's sleaving. As you will find out, well the one I made and ran tests on. It will be interesting to see if yours is ok or not when you draw current.
Don't say i didn't warn you. Oh well, have fun.
A G
