0 Members and 246 Guests are viewing this topic.
NickZ
   In trying something different, I placed an air core wound with some turns of wire and placed it next to the grenade antenna coil. And I got over 1000v on it with no load. So, then I connected it up to a full bridge rectifier, and back to the Kacher's input. The bulb on the grenade brightened up. The rectifier diodes stayed cool.
   It seams to behave something like the Vasmus devices mode of operation. And, it seems to have little to no effect on the grenade coil, as far a draining or reducing it's output, as the bulb at the grenade's output brightens up instead.  Something to play with, maybe.
   I'm still trying to figure out how Poma (Roma) does what he does, also. Using just the Kacher circuit as an input source.
apecore
Quote from: NickZ on August 15, 2016, 10:06:16 AM
Nick,
its good to hear you are trying all kinds of things. Out of the box thinking could give some unexpected results,...  wich will bring us futher and futher.
I have at this moment one bright  bulb of 25W wich is directly connected to the grenade,.. see picture......only ground is also connected to the grenade  (otherway around as shown in the shematic)
I will try your last setup,.... how many turns did you make the aircoil?
I tryed to place a simular coil as the antenna right next the antenna coil.....it gave me after rectifying 50V,...small current was going back to the battery (powersupply kacher)
But i saw no gaining in brightness.
I have to go back and get the Vasmus more focussed,.... see what more there is to play
Status Yoke,..
As we speak i am finishing the yoke drivers, so i hope i can test driving the inductor tomorrow.
MF,
I have also finished building the braker tesla schemetac from MF,...i guess the pulsation during "ON" stratus has to be in the resonance frequenty of the tesla coil?
I think the TL914 circuit cannot reach the 1.25Mhz so i must find a way to let the kacher start en stop as it resonate on itself.
Do you have a link where i can follow the Russian forum?
NickZ
   apecore:
   Your system is looking better and better. Thanks for turning your coils around, also.
It's good that you got the 25w bulb running brightly. Try two, or three bulbs on as well, to see to what extent they will light. That will indicate just how strong the Kacher's output is.
   The long Kacher secondary coil will probably not resonate at 1.2mHz, unless you shorten it. As the higher the running frequency, the shorter the secondary has to be. But you might be able to find a suitable harmonic frequency that will work, like possibly at 600kHz, or so.
   I connect the Kacher circuit transistor negative rail to my outside Earth ground. As well as the end of the grenade output coil, so both are connected to the same ground.  If you don't connect the grenade to the Earth ground, there will be HV running throughout the whole system, and burning out all the delicate control circuits.  So, please remember to ALWAYS use the earth ground, which should also be the same size as the grenade output coil 37.5, or so.
Several of us have disregarded that advice, and have paid the price.
  The stronger that the HV signal is, the more harm it can do to the yoke's circuit delicate control components, if not earth grounded.  Although it looks like you're very quick and proficient at assembling the drivers, watch out with the HV impulses.
  The extra coil that I had used next to the antenna, was a 40 turn magnet wire air coil, wound on 1 1/4 inch pvc pipe, with some ferrite in the former pipe, which also seams to help. I just had this coil laying around.  I would think that 50 turns would be better. Once rectified the voltage does drop to about 20v, or so, but that can be adjusted by adding or removing turns on the coil to get the best running voltage.  A filter cap after the rectifier is also needed.  The Kacher transistor temps will also increase, so watch out for that if you try it.
AlienGrey
Quote from: NickZ on August 16, 2016, 10:16:08 AM
   apecore:
  The extra coil that I had used next to the antenna, was a 40 turn magnet wire air coil, wound on 1 1/4 inch pvc pipe, with some ferrite in the former pipe, which also seems to help. I just had this coil laying around.  I would think that 50 turns would be better. Once rectified the voltage does drop to about 20v, or so, but that can be adjusted by adding or removing turns on the coil to get the best running voltage.  A filter cap after the rectifier is also needed.  The Kacher transistor temps will also increase, so watch out for that if you try it.
If you think the Katcher winding is too long have a look at Geo's device his looks full wave to me..
ask yourself this question is a 1/4 wave half the frequency, a 1/4 of the frequency or double the frequency or four times the frequency ?  in this database you will find an interpreted article all about this phenomena and how it works.
AG
apecore
Quote from: AlienGrey on August 16, 2016, 10:39:52 AM
AG
AG,
Do you have a link to the mentioned info from GEO?
Thanks in advanche
