0 Members and 147 Guests are viewing this topic.
apecore
I think kacher don't resonante on coil length in full or half wave etc.
It is the combination of coil induction and capacatity  (coil capacitive and the capacity of the connected items at the top)
Thats why the frequentie drops when the top of the tesla coil is connected to the ferrite and to the antenna coil.
Getting the frequenty higher is by reducing the inductance (shortening the secundairy coil)
Nick, thanks for the recommendations about the grounding and the damage HV can do.
I did run my push pull yesterday already,.... of course with grounding.
i see on the scope the kacher wave moving on the push pull frequentie (25kHz)
I will post some pictures of it later.
apecore
Quote from: NickZ on August 16, 2016, 10:16:08 AM
   I connect the Kacher circuit transistor negative rail to my outside Earth ground. As well as the end of the grenade output coil, so both are connected to the same ground.  If you don't connect the grenade to the Earth ground, there will be HV running throughout the whole system, and burning out all the delicate control circuits.  So, please remember to ALWAYS use the earth ground, which should also be the same size as the grenade output coil 37.5, or so.
Nick,
I have the emitter of the karcher transistor, grenade (right side connrction), inductor (left side/after tuning caps) and negative of load (film capacitors) connected to the same ground... wich is about 30 meters away......so no 37.5meter........i have expand the wire lingth i guess.
the other ground (house grounding) is only connected to de negative site of the batterie pack and thus with all the elektronic control circuits.
I have attached 4 photo's;
1- i connected the probe at the inductor (fase side /left).... kacher not activated.... the 100W bulb lights as most at this chosen frequenty.
2-,..same connections as the first one,...  only kacher now activated
3-,... probe connected to load capacitor (+),.... everything running with 100W bulbload
4-,.. overall setup
kacher is using 1Amp,....  push pull takes 2Amps,...  so max. 3 Amps total when all connected
Mounted some new cooling radiators,.... have no heating problems.
Next i will try this setup with  a inductor 18,75m and see if something changes.
NickZ
  Looking nice!
  There's still one thing I would do, though. Which is to change the toroid core for a real 3 inch Tv yoke, instead.
When you can, of course.  The more bulbs that you add on, or the higher wattage bulbs will vary the frequency. There is a reason that Ruslan and Akula both use high wattage bulbs. As they allow for more input to come into the system, via, Aether, or what ever.
   There is at least twice the amount of ferrite surface area in the yoke, compared to the toroid core. And twice the amount of wire it takes to wind it, which means more output, also. And the yoke was made for running at around 15kHz, I heard, but it's been a while since I checked on that.
  Perhaps Itsu may want to step in and give some advice and ideas concerning tuning for the various frequencies, and so forth.
  Akula's first self runner would not self run on the smaller yoke core (2.5" dia, or so), so he changed to using the bigger 3 inch cores, instead.
   As far as the sync between the Kacher and the induction circuit...  It may not be right at 1/4, 1/3, or 1/2 wave, like we've heard. But, that's what we'll have to figure out. And, it may not be the same, for the different replications being tried.
   But, it's there, somewhere...
   apecore: You might also want to check the videos on YT by our member here, Tomtech29.
Like this one below,  he has several more, as well. And get up to speed on what's been tried by the different guys here.
  https://www.youtube.com/watch?v=7m7TVIKrDno
Tomtech29
Hi everyone.
It's nice to come back after a long break NickZ - Continue to struggle, with this device takes ?
- one thing I can tell you from my experience that adherence to the theory of Kacher " It is a lure for small fish"
incorrectly to think about a full sine curve on the Tesla coil!
because of the fact that You fall into the same phase as the magnetic flux of the alternating current and besides heat up rectifier diodes!
and such method is not obtained from the impactor on the current course of the sine wave.
Here we spent quite a few hours to figure out the system and we learned a lot from each other I thought a lot about what he said:"as you put the oscilloscope probe next to the antenna"
notice how impulses as pulses accelerate carrier waves.(as shrinks and expands) This can be observed on systems with synchronization as (Pll) with variable frequency
and the left and right of the changing range.
Pay attention to the older schemes! the whole game is held from Dally and there what? pa pa pa pulses or Kapanadze used with sparker .
And now, a replay of history:
https://www.youtube.com/watch?list=PLC7684829E98CAD74&v=jMaXwE3-oNc
something is shown to fly back unbelievable :D
as simple as the hammer
_ I have some thoughts that there is a gap between the windings in the (inductor Cww_Cww) It is a place in the middle where the grenade is the gap or how to call a node where penetrate the impulse.
and no coil and must train on a closed circuit with the frequency of the current resonance and no voltage.
How about the carcass to a turning point of the interrupter we will create I'm on the lookout and observed actions :D
NickZ
   Tomtech:
   Good to see that you're still here, and on the lookout.
   Thanks for your reply.
   I'll look at the video that you posted. I hope to see you back on the bench.
   We missed you, along with some of the other guys that aren't posting much anymore.
    Like Itsu, and ...
   But, now we have new motivation with apecore. He is quick and does clean work.  No mess of wires all over the place.
