0 Members and 625 Guests are viewing this topic.
NickZ
  apecore:
  You mention: "In reaction of your suggestion to replicate al things exact as the original setup i must dissappoint you.
I need to play around on all parts of the setup in order to learn about its functionality."
  You will not disappoint me no matter what you do.
But, you will probably end up doing it the way it was designed, as you are even now doing. There have already been many months, and year's worth of previous work to obtain the results that only the Russians are now showing.
I guess that nobody told them that   "it's not possible".
   Any ways, I'd like to see those one inch screamers.  Oh yes...
   I'm deviating from the original way of doing it, also, for now.  By using a Mazilli/Royer circuit, to prove the point to myself.
But, I do have plans to make the TL494/fet driver push-pull circuit, as well. When I can get all the parts for it.
   As I think that each additional component used on a system only reduces and filters out it's output. Not really adding anything to it.  Therefore, the simpler the circuit, the more power it can have. Roma's self runner,  is the living proof of that, as I have always thought as well.  As I think that the amplification effect is not based on the nano second, PLL phase lock, or all the other complicated and numerous components, and additional circuits. But, on simply achieving the right HF HV pulse, to properly heterodyne with the magnetic induction circuits. Such a Poma has shown, without needing to use a 100 component circuit to obtain the same 4000w output.
  Sorry for my poor video resolution. It was bad because I didn't use a camera, I used an older Galaxy cell phone instead, which has a lousy camera. That's what I had one hand at the moment, and I wanted to show that moment, blurry, or not.
  But, yesterday I made another new video using my wife's new Galaxy phone, and the camera on it is awesome. I did not upload that newest video, as it was just a camera test. Although it shows the best and clearest images of what I'm doing, to date.
But, you'll see that my next videos will be much clearer, using a much higher resolution.
apecore
Quote from: AlienGrey on August 24, 2016, 10:04:13 AM
Interesting conversation starting here Apecore, I did notice you had larger than normal Katcher length how did you wind the device it in the end one full wavelength? with a node at 3/4 wave and 1 and 1 1/4 wave ?
also my original Katcher and waveguide made for tests.
Regards AG
you have a nice kacher too....
My kacher has 34cm windings, it has probally 325windings/1mm wire
I have my first node at 10cm and after that every 2 cm.
You can see in the pictures how it looks like and how it is connected.
The reason why i keep hold of the 1.25mHz with the 325 windings is that i have now a different antenna....the frequenty drop is not as bad as what it does with the originally ferrite/ antenna.
I have also attached again a 2 video's,.... to bad i stopped it instead of pausing....( first one shows how the internal antenna looks like and the second vid gives the results..)
Btw.... i discovered that my normal bulp is not 60W but 25W so i cheated a little :-[ :-[
therefore i connected first the 25W and later a 100W bulb.
https://youtu.be/x6ROpqFF42M   (setup)
https://youtu.be/DCxPjlvgWK0   (result)
Nick,... i agree totally the less components the better,... Romaselfrunner is also my goal.
Streamers.....  Oh Yes,.....i show it in a video...
https://youtu.be/m9zNF1wOBGU
And maybe you are right that at the end we will be back with the originall layout,.... maybe,.. who will know?
Don't pay attention too the second system it is complete clockwise build. --also one of Roma ideas,.... or was Ruslan (Fedor 001)
Tomtech29
Hi
NickZ
I would like to ask who is this : Roma's which has self runner, so I can not really associate you can present its progress in this area?
very difficult to find something in this topic and in the Russian forum subsided
what he discovered?
- scans some snapshot of information about the  self runner, and I found something:
https://www.youtube.com/watch?v=2libK6MpOZY
but the absence of any comments or technical suport
screen shots look as if it was a hysteresis :D :D  crazy but the desired effect.
throw any link aforementioned creator ?
Thanks.
Tomtech29
Hi.
apecore
I mentioned Establishing the appropriate resonance point
See this section select the appropriate capacitor to the  (G coil):
https://www.youtube.com/watch?v=RdEnx6hfshQ&index=3&list=PLK7gxeQv5qT44ZM5TVnBW534ogPJnrXjg
- you will not see anything when the scheme reduces resolution !
See where the cylindrical shell I marked with a red line.
most likely There is disposed an aluminum foil ! and the tank LC is not grounded !
the rest of the scheme should agree so only the attention of the mount driver IR2110 is unlike other
It may seem complicated at first glance.
Tomtech29
Excuse me something I have a problem with editing entries and the photo is too large
