0 Members and 600 Guests are viewing this topic.
apecore
Quote from: NickZ on August 29, 2016, 05:28:27 PM
   Geo:
   Nice going!!!  And thanks for sharing.
   It's great to see your new drivers, and the effect that moving the yoke next to the grenade can produce, and the brighter bulbs now, as well.
   My circuit is working pretty well now, also. It seems to run a bit different than yours.
   To answer your previous question, no, I can't brighten the bulbs with my hand, only to dim them, the closer I move my hand towards the antenna coil.
    I'm back to using 24v for the ZVS circuit, same driver but all new parts, including the 18v zeners.
But, I didn't get my order of the MUR1560 rectifiers for a new bridge, so I'm back to using my current IN5408 rectifier diodes/cap for the full bridge. The commercial rectifier that I tried out, did not work out too well. So, now my flyback/ bridge diodes are still working, but are getting way to hot now, as I'm using higher voltage and higher amps at the input.
   Since my yoke secondary coil (28t) is connected to the Kacher's input, I get 1" streamers now, similar to the ones that apecore has shown. And their RF burns hurt, real bad.  I hate to say... my finger smelled like B.B.Q hamburger...
  I'm running the output from the isolated grenade's 168t coil, only.  No rectifiers on that output coil yet, as they aren't available here.
  I can show a decent amplification effect on up to a 100w bulb now, but not on any higher wattage, or even more bulbs.
  I'm running three 100w bulbs as the load on the induction circuit. But, can only see the "effect" when using up to 100w loads, with my current tuning at this point.
   I would like to get some of those big bulbs 300w or higher, but, for now I'm doing it with the bulbs that I can get here.
However, I do have big 230v 250w bulb, that I'm about ready to fire up.
So, I'm still tuning away... you know how long that can take... but I'll post another video soon.
  PS:  I don't have a problem with HV HF interference on anything. I have a flat Tv, desktop pc, tablets, mouse, cell phones, etz...
all within one to two yards away from my device. NO interference.
  Nor do I hear anything, such as the high pitch ringing sound, at all. from my set up.
  Good to hear that you can use a scope.  Although you've done a great job even without it.
        Best of luck,
        NickZ
Niceto hear Nick you make progress.
But i m really concerned how you bake your hamburgers....or..
I hope they aint made off human flesh?...
Believe me here they smell different ;D
Geo,
You do surprise me everytime....i can' t wait to hear if it is capable off selfrunning.
Btw...is it possible that you make a small drawing how caps and coils are connected etc?
I would try it doing the same way to see if its result is simular.
Stivep,
Always doing research and getting exlusive information posted.
People as you are never enough on forums lije this.
May i ask you also a mindbreaking question?
Alexeeew.serqey uses aluminium antenna for emmitting the kacher output.....is there also same as the ferrite story a explanation why this is preferred?
At last...short update from my bench...
I am now busy replicating the alexeew sergey setup.....using the breaker kacher functionallity.
Rewound my grenade and inductor (3 layers)...tesla coil same lenght as inductor.
So almost finished..vew components yet to come.
For the time being i could try to do a similar test as Geo did last night....nice oppertunity to tune the system.
I will be back on that this week.
AlienGrey
Quote from: apecore on August 30, 2016, 04:37:12 AM
Did I miss something here ? (why is prosecesed shop meat always gray ) has it been 'passed' by the gov ? ;) ;)
For the time being, I could try to do a similar test as Geo did last night....nice opportunity to tune the system.
Which circuit are you thinking of using I have done a couple of PCB's in lab centre (format Aries) if you want the file, there are a few mistakes in the original drawings he sent but managed to fix with a bit of thought.
also, Aluminium foil is wafer thin and push fold contact will oxidise copper foil would be a far better idea as you can solder to it easily but the coil format windings are all different. ;) word of warning though (not offensive I hope) measure wire length on any windings and DO NOT TRIM use capacitors for resonance tune. All the masters tell us this for a reason as it's the wavelength only a novice makes this mistake including myself.
regards AG
apecore
Quote from: AlienGrey on August 19, 2016, 01:11:33 AM
This might be of interest to anyone building the Sergey card, as the current Nand can't successfully drive the Mosfet driver as is and two unused gates would be needed to correct the problem.
AG,
Thanks for your comment..
This circuit i have now...it was in vw weaks posted here.
If you have a working version without defects...you are welcome.
Yes i will not adjust the wire length...only difference is i use the 37.5m .....instead of 38m.
I think i will email alexeew for some frequenty details.
NickZ
   Last night I did a couple more tests, after watching Geo's videos.  And I was also able to light a 100 bulb just off of the 0.47uf WIMA tuning cap, without the bulbs on the 168t coil dimming. I had shown that before, but, now the 100w bulb lit to a much higher degree, than the same type 100w bulb placed on the grenade's output coil.  Pretty interesting.
As up to now, I was only able to light smaller bulbs on the capacitor, not 100w bulbs. Of course I was only using 12v, and a couple of amps to run both circuits, and now I'm using my 24v, 10amp power supply.
   Geo:  Looks like you're about ready for the moment of truth... I'm still holding my breath.
Hoppy
Hi Geo,
Nice progress to show the 'effect'. Good work.
Taking your measurement of around 60V across your 300W lamp and given that a hot resistance in the order of 48ohms (for fully lit bulb), the max power being dissipated by the bulb works out at around 75W. However, as you comment, the lamp is perhaps half brightness to your eye, so the power dissipated is likely to be somewhat less than 75W. Your power supply is showing a delivery of around 120W, which seems about right. There is not a significant drop of current when additional bulbs are connected (although I do see a visual drop in brightness) because the current to the lamps is pulling the series resonant circuit off its peak tuning point, thus reducing the overall current to the lamps. In effect you have a semi constant current driver. Its important that you get a good handle on how much power the bulbs are actually dissipating in comparison to the power being delivered by the PSU. Also, from my experiments, bulb brighthess v power consumption can be very visually misleading, especially when the supply frequency is much higher that the grid frequency. Good scope shots will give a much better understanding of the actual power being dissipated.
