0 Members and 75 Guests are viewing this topic.
AlienGrey
Quote from: MenofFather on September 01, 2016, 06:49:08 AM
No. I dont have.
We need to trace out the circuit I don't think the values are right as the first bistable timer is wiped out by the second as it is the same polarity and longer duration, also the 47-ohm load resistor gets very hot and burns out.
but I think it just needs some work doing on it, katcher section.
regards AG
conico
I have seen many replicas of Ruslan,not all are successful, perhaps because Yoke coil location.
Between Yoke and grenade coil is 90 degrees. If you move the yoke , the effect will not occure.
See Geofusion movie.
Is just luck for Geofusion to have in the right place the yoke coil.
Perhaps i talk to much.
T-1000
Quote from: AlienGrey on September 01, 2016, 08:28:27 AM
is this the same card, sorry about the lens none linearity it's not really bent like that.
What's the extra bits for, anyone got the correct circuit for this card or know what it is really for ? what i mean is have i got to alter it's tracks ?
The 74HC14 in front with IR2110 driver and 2 3 pin terminals.. It looks like PLL with push-pull board ;)
Tomtech29
Quote from: conico on September 01, 2016, 09:03:27 AM
he.. It has nothing to do with the 90 degrees between Yoke , you do not see that one side of the half bridge it is off.
due to high voltage near the gate of the transistor and that the small generator Tl 494 is unstable near as strong field  from antenna
- It reminds me of something "Dog one" on one of the screenshot .
(I'm for doing some concerns that such a claim)
- any metal part of the intercepts and moves it to the low-voltage sensitive integrated circuits.
and the squeaking and cracking this and other reasons frying MOSFET!
    I say jokingly: "and arriving at power , may the force be with you" :D)
all the options we consider all manner of angle observation perhaps something there occur other phenomena?
the more developing theme is something new will.
Hoppy
Quote from: Tomtech29 on September 01, 2016, 03:45:47 PM
Hi Tomtech,
I raised this issue way back as the reason I think for the increased bulb brightness when the Kacher switches on.
