0 Members and 36 Guests are viewing this topic.
Grumage
Dear Nick,
I have got my "teeth" into T-1000's test case at the moment but the "tuning" is really tricky!!! as there are 6 coils that all have to work together.
I would really recomend T-1000's help as he has a real insight to these devices. I spent nearly an hour via Skype with him last night and together we made some progress.
If I am correct in my understanding? What we are trying to achieve is a standing wave on a coil so that a pickup  positioned in the right place will recieve those impulses without actually affecting the primary side. Someone correct me if I am wrong with this?
Best wishes to you and the Guy next door......... Grum.
T-1000
Quote from: NickZ on May 21, 2013, 10:58:02 AM
    I have over 1000v pulsed Ac coming into the center tap of the opposite wound 12 turn coils on the yoke.
Maybe you can explain what you mean by resonance in parallel, in my case. Are you talking about making the 12 turn coil resonate with the 3 turn coil, using a capacitor?    Clear picture of my set up (below).
Ok, can you explain why you are pulsing high voltage into yoke? The 12V driver is enough. Also the yoke is isolation transformer in this case. The secondary 3T winding - this part can be used for resonance in series for air coil transformer.
As long as you keep with square wave into yoke primary you are fine for first step to make wrench heated up in air core transformer...
Quote from: MenofFather on May 21, 2013, 12:47:19 PM
One woman, saying, that she have at home free energy generator, she say, that need on tesla coil wound other coils of 300 windings.
In that case it is better if you visit her and make complete drawing of schematics with all details before attempting to wind coils. The description is too fuzzy to get anything out of it.
Quote from: Grumage on May 21, 2013, 01:34:56 PM
For first taste of standing wave, yes. Later on the test case can be modified to reconect choke into series to primary coil on air core transformer so more sensitive part can be tuned in same way for standing wave. Also there are at least few ways to see what is hapening before understanding will come on how to use complete circuit with Tesla one wire transmission system for magnifying to some serious electricity.. :)
MenofFather
I cant vist her.
I draw schematic how can be. One user in one forum post this text
"<< У меня есть БТГ или называйте как хотите, поэтому в связи с этим, мне все эти форумные дискуссии интереса не представляют.— Princess, Вчерашние 21:07[30 апреля 2013 г. 21:10] Princess:[/font][/size] [/font][/size]<<< Схема будет зависить от того, какой мусор у вас завалялся в ящиках стола и на полках.— Princess, Вчерашние 21:10[30 апреля 2013 г. 21:12] Princess: [/size]<<< А принцип: берете обычну ТТ, помимом ВВ обмотки, нужна ещё обмотка на 300 витков, на нее синус с автогенератора, так же там будет катушка возб. такая систкема постоянно в резоанснсе, теперь с индуктора подаете импульс в такт синусоиде, при ее прохождении пиков через верхние точки. все. Происходит мощный всплекс тока. Который увеличивается если подключить большой лист металлла или землю.— Princess, Вчерашние 21:12[30 апреля 2013 г. 21:15] Princess: <<< Схемотехника любая, от того что есть под ругой, главное точно на синусоиду в верхних точках, должен бить короткий испульс тока.— Princess, Вчерашние 21:15[30 апреля 2013 г. 21:14] Princess: <<< Вот и вся суть. Обмотка резонирует на частоте синуса, скажем на 2500гц, с этой же частотой нкладываются узкофронтальные импульсы, в резонансе начминается ещё один резонанс, и как результат растет ток.— Princess, Вчерашние 21:14[30 апреля 2013 г. 21:16] Princess: <<< Почему по схеме автогенератора? потому что он постоянно держит резонанс, при любой нагрузке. автогенератор лучше двухтактный, но только не каченрный, там невозможно управлть.— Princess, Вчерашние 21:16[30 апреля 2013 г. 21:26] Princess: <<< Я не хочу никому ничего показывать, чтобы не занимались "повторизмами", себе я сделала, и вы все тоже по этому принципу сможете сделать. "
T-1000
Quote from: MenofFather on May 21, 2013, 02:29:17 PM
I cant vist her.
In that case I know who nick named Princess is and that is almost exactly same what you seen in my previous post:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg360759/#msg360759 ... :D
And you need to remember and understand this quote from N. Tesla before looking on circuit:
"From theses experiences it became apparent that the fire balls resulted from the interaction of two frequencies, a stray higher frequency wave imposed on the lower frequency free oscillation of the main circuit.
As the free oscillation of the circuit builds up from the zero point to the quarter wave length node it passes through various rates of change. In a current of shorter wavelength the rates of change will be steeper. When the two currents react on each other the resultant complex will contain a wave in which there is an extremely steep rate of change, and for the briefest instant currents may move at a tremendous rate, at the rate of millions of horsepower.
This condition acts as a trigger which may cause the total energy of the powerful longer wave to be discharged in an infinitesimally small interval of time and at a proportionately tremendously great rate of energy movement which cannot confine itself to the metal circuit and is released into surrounding space with inconceivable violence.
It is but a step, from learning how a high frequency current can explosively discharge a lower frequency current, to using the principle to design a system in which these explosions can be produced by intent."
P.S> Princess repeated this quote in own words on Russian language.. ;)
verpies
