0 Members and 123 Guests are viewing this topic.
NickZ
   Right: But, that may be a long ways away, still. Or not...
   The only reason that I bring it up is because Geo has compared his device bulb brightness to grid powered bulbs.
I see only about 20-30% brightness, perhaps the rest in heat. Further tests will either disprove or confirm this.
As a single 100w bulb on the grid is brighter than all his bulbs,  unless you're blind.
   Therefore NO OU, as yet, but is possibly a step in the right direction.
    The "interference" is caused by HV grounding to something. Which will eventually burn something out, like the push-pull components. And needs to be fixed.  If your hand near the antenna causes a brightning of the bulbs, it shows that the system is not fully tuned. As a hand near the antenna should only dim the bulbs when the device is running at resonance, as Ruslan has shown,  not to brighten them.
  AG: I'm not knocking it at all, I'm looking for the cause of the "effect", and trying to reproduce it,  instead.
As a comparison, the Mazilli can light 700w worth of bulbs, even without the Kacher, which doesn't mean too much to me.
AlienGrey
Quote from: NickZ on September 04, 2016, 09:13:09 AM
Nick get your head round this 'a sign wave' what is it ? 2 dimensional (a line bouncing up and down) or 3-dimensional rotating screw effect, what parts of it can you use ? and what is waste ? So what parts can I use to get value for money out of the sine wave energy I'm paying for ? this is important aspects you could haqve overlooked if you want to move on.
Also what can I add or alter in order to get the maximum efficiency out my energy ?
AG
NickZ
  I don't know what you mean. But, it was a sine wave on the TopRuslan's Kacher circuit, which is the self running version that I'm working on, in my own way.  I'm not trying to get the Kacher's sine wave to do anything other than to sync with the sine wave of the my induction circuit. Yet it can partially light a 250w bulb by itself.
AlienGrey
well in a sine wave the only useful part is the current peaks upper and lower, our friend Nelson talked about poking a high voltage onto the peaks at that point and another is tuneing to the 4th harmonic in phase with this also, that is so well known it has to work their is a device called the squealing pig device it's on the net somewhere parts of it do so behave as the vasmus device.
Hoppy
Quote from: NickZ on September 04, 2016, 11:02:24 AM
Yes, the HV is affecting the push-pull and Geo's opinion is that his device is fully tuned for maximum brightness. However, as you say it is working opposite to Ruslan's device but given the excitement he was displaying in the video, I doubt he would consider that it needs to be fixed. It does not necessarily follow that his device is not tuned just because Ruslan's device works opposite. We need to understand in detail how the device should function and its components interract for self-running before we can be sure how it should be tuned. For all we know Ruslan may not have acheived true self-running and Geo could be on the right track!
