0 Members and 574 Guests are viewing this topic.
apecore
Guys,
I ve been testing also for a while trying to get also the GF effect.
I rebuild my setup as drawn in the Ruslan 2016 (version: redraw GF)
Also i get no positive influence from kacher circuit.
I have best results by adding a parralel cap at the inductor coil,...  it gives at 200w bulb load 120Volts.
Drawing 5Amps//24Volts total
Further i have also accomplished by adding some chokes and diodes so that the power to the katcher is comming from the loadside..(Directly as a second powersupply to the kacher primary
I see the amps drop down to 0.2A from the main power to the kachersystem.....So power is comming from the load now..
But same time my Amps to the push pull system rises with 2.
So i can also conclude out of that ,........ kacher HV isn't delivering power to the yoke/ output coil
But by doing more test i can now monitoring my Amps,..it would indicate that HV influence is getting on track,.......
So Nick,...i think we have same results generally,...  i hope there will be some suggestions,.....
I hope Geofusion is going to tell us that the drawing is not his latestversion,...   so that would be  :)
NickZ
  Maybe, the kacher pulling the 2A from the induction circuit is good. At least it works that way.
   Can you describe how you were able to do that. As I use a fly back core and coils to adjust the voltage going to the rectifier/cap, as well as a choke.
apecore
Quote from: NickZ on September 04, 2016, 03:55:44 PM
Nick,
Hereby how i have connected it.
I have best kacher results without mediator coil
Could be that the chokes are not chosen as best induction,... but these i had ready for use.
So perhaps not the best configuration but thats for later.
I hope it is clear enough in the picture
Tomtech29
Quote from: apecore on September 04, 2016, 04:42:51 PM
Nick,
Hi guys
I did so quickly on this film maybe it good lead (set the tone here on the capacitors):
https://www.youtube.com/watch?v=288uWzWRKAQ
- just set the pulse width 2 of between 40% and reduce the peak amplitude of the resonant LC.
- I used a capacitor in series with the 28T.
- set so that the magnetic flux under full load does not exceed the power supply output current.
- I use 500 watt bulbs 230V. the important thing is that the system is not its tuning push-pull only has to provide a magnetic field.
as soon as I find some time and desire to try to run a high voltage circuit and see if we can lighten these bulbs, I'm very curious effect Geo.
and to see that there was something better.
NickZ
    apecore:
    Ok, thanks for drawing that diagram up. That's what was needed, and I'm working on it connecting it up that way.
I hope Geo draws up something similar of his device, so we can all get on the same page.
    If I place diodes like the 3 amp ones that I have anywhere on the induction circuit, they go up in smoke in no time.
I'm still looking for the MUR1530 rectifier diodes, or something similar to the diodes that you are using.
     I also find that a choke is needed for sure,  next to rectifier. It drops the input to the Kacher though, and it also gets hot, but can take it better than the diodes.
   Tomtech:  It's good to see you on the bench... again.
   I'm finding something similar. And once that happens I can't control the frequency, it seams to lock on somehow.
   If you are seeing the load stay the same, it would be a good place to connect the PS for looping back from that point.
                       Good luck with your set up.
