0 Members and 58 Guests are viewing this topic.
justawatt
justawatt
all three video i shared have special type of bifilar winding with one end not connected .
please see other 2 videos i have shared.
https://www.youtube.com/watch?v=jdLqIYAFwKE
AlienGrey
Quote from: apecore on September 14, 2016, 01:43:05 PM
Guys,
Lets get on track
As T-1000 explains the Akula approach...it also gives another look at our grenade....wich we all configure on 8Mhz...(37.5m)
As posted by T-1000....tesla coil gives by measurement the frequency at the desired kicks to the grenade.
In one of the last sentences is mentioned that the grenade is made based on the outcome of the kacher.
As i read it.....i think that the wire length of the grenade is related to this kacher frequency.
So the mystery length of 37.5m is only valid when the 2Mhz is generated by the kacher system.
This approach would lead more to the standing wave principles appearing in the grenade.
Gives this also answers to AG about the coil discussions?
Absolutely 2mhz is the 1/4 related wavelength to 8mhz 16 and 32 of sorts ! Whether the whole thing works or not remains to be seen !
AG
NickZ
  apecore:
  I think that it is important to verify what you think that T-1000 has said. As I believe you have it backwards.
  As far as I understand it,  and as I've already explain, previously.  The first thing is too obtain the proper sync between the two induction circuits. Which means that the 9m or 18m induction coil, is synced with the frequency of the 37m coil. By adjusting the TL board pots. After that, the Kacher is adjusted to match and sync with the induction circuits. And not the other way around.
   However, what may be happening also, is that even thought the idea of nodes, and frequency matching is important, the connection methods can override this to some degree. Which means that no matter how long your Kacher secondary coil is, there will be some interaction with the grenade coils, if, the Kacher is strong enough to do so. This is what I'm observing by studying the different videos that are out, with each and every self running device running a different frequencies, while using different size Kacher secondary coils, and still able to produce some effect. However, it also may be that some of the previous self runners were fakes. Therefore the confusion.
   If you look at the Akula schematic of his second self runner, he shows that the induction circuit resonant point(s) are 17KHz, 27KHz, and 37KHz, not MHz. While connected to the circuit, not it's free running frequency. Which also means that the Kacher should not be running at that same frequency. But, in the Mhz range instead.
Although I have not really seen the 1/4, 1/3, nor 1/2 wave rations, as the best frequency match, there may be something to that, as well.
  If you use a spectrum analyzer, you can see just where the best resonant peeks are found. Although they can and do change, and are not fixed points, at all. As changing the running frequency does induce different resonant points.
  So, in order to verify all this, if you think that 2Mhz should be the proper matching running frequency for the Kacher, in order to sync with the grenade. Try it and see.
  Also, check Itsu's #15 video, that was the last we have heard from him.   Bummer!!!!
  He also did a frequency sweep in his previous videos, using the spectrum analyzer, of the entire use able ranges, but found no outstanding best resonant point, if I am not mistaken.
   TomTech:  Sorry, but you are right, I did not have the Kacher on in my last video, unless the neon indicator light is on, at that point only the inductor circuit was on.  I thought that I would clear that up.
T-1000
Nick,
akula method is from other side. First he match Tesla coil frequency and voltage to the response of the ambient energy, then he build receiver (grenade coil) to siphon and charge bifilar coil on same parameters. The last bit is the induction series push-pull which is in sync with Tesla coil on low frequency resonant harmonic.
Hopefully that will clarify tuning method.
Cheers!
