0 Members and 47 Guests are viewing this topic.
Enjoykin2017
Quote from: NickZ on September 26, 2016, 06:23:44 PM
  As I mentioned to Hoppy my whole system works better, using larger wattage bulbs for the load. As the load becomes part of the system, it allows the Kacher to work better, also, with the higher loading.
   Look at how Geo's 100w Halogen bulb loads up much brighter than a regular 100w incandescent bulb does. That load is important, for better impedance, or for what ever reason.
   Using a single 100w bulb, or using 3 100w bulbs, makes my system do different things, and go into different resonant points, of which there can be more than just one. The device creates different resonant points, as the frequency is changed and altered.
   I'm still just getting a grasp on all of this. One step at a time.
Hi Nick Zec !!
Suitable load is crucial for correct impendance matching permiting stable work of BTG. In every working BTG i have seen there was always presented high load. Before several years then i am analysed Floyd Sparky Sweet VTA (Vacuum Tube Amplifier) was condition of minimum load permiting device work. What is interesting like you have observed Sweet VTA worked much better with very high load. Once he has intentionally made short-circuit at output and got whirlpool like sound tornado. He immediately turn-off device but seems that he had been irradiated with unknown force-field and soon after he passed away. I have knew a several people who made experiments with scalar-torsion fields (magnetic-matter) and they are all passed like Floyd Sweet.
Nick do you have any dizziness and headache in the region of head or neck while long running your Katcher ?
Many people have. So now you know a reason why i am suggesting verpies to make Nanopulser based on DSRD diodes like Dally did.
Somewhere i have reading from your old posts that your Serbian father was a excellent nuclear physicist. Do you have some of his equipment for radiation meassurements and if yes would you like to do some prospecting radiation meassurements in vicinity of your working Katcher and device ?
ps: By the Edward Lee Dally is alive. He was posted a new comment about two month ago.  :D
Waiting him come back to game !!
reg.
Enjoykin
NickZ
  As far as feeling any negative effects?  NO, not in the last couple of years.  Nor feeling any positive effects from it, either.
But, I don't run it long term, as I'm working and testing and changing it, all the time.  So, no long term "burn in" tests done as yet.
   I have been getting into the frequency ranges, like Geo has, where the whole system starts to go into the "Caotic Mode", and ring, sing, vibrate, hum,...  even making sounds like when one is tuning a short wave radio.
   Enjoykin:  I absolutely hate even the word nuclear.
  AlienGrey:  I'm still very interested in the Poma or Roma self runner device.  If any more info about it pops up, or any working replications of it from the Russian guys gets shown,  let us know. Thanks for the link.
Enjoykin2017
OK Nick Zec , thank you for honest reply !!
Now come back to topic. It may be interesting !!
LC-RESONANCE & STANDING WAVE RESONANCE MATCHING CALCULATOR !!
Calculator by Вячеслава Горчилин
To share Calculator link of this project it is necessary to copy the link and paste it into the blog, a forum or other website.!!
It is well known fact that the coil has own inductivity and capacity , so has own LC resonance. If we consider the coil like the long line waveguide , then at certain frequencies in coil will self-arise resonant mode of standing waves.
Correct matching of these two modes LC & WAVE , at certain frequency leads to sudden sharp rise of Q-factor of the coil in real circumstances.
This simulation make operational exact formulas for determination of inductivity and own capacity of the coil , also with the further data considering the non-linear nature of wave propagation speed depending on wire property , frequency and parameters of winding.
On a graphic , value on a horizontal axis represent the winding coefficient which is in postponed relation to wire spacing and wire diameter. In fact, this coefficient defines construction of the coil. On a vertical axis values of frequencies in megahertz are postponed. The orange curve render LC resonance, and blue curve WAVE resonance.
To the right of the diagram are provided coil data which are counted for crosspoint of these curves  For extension of coil computing range , additional connection to the coil an extrinsic additional capacitance is provided, and for particular treatments operation on any upper harmonics of LC resonance is added; Initial setup is the first LC harmonic. In the addition is also possible to take in account more data entering coil frame relative dielectric permittivity and its thickness.
By default, the relative dielectric permittivity of coil frame is equal to unit.
Calc Link: http://gorchilin.com/calculator/reactor?l=40&d=1&D=110&L=0.25&G=1&C=0&E=1&dt=0&lang=en
Enjoykin
Enjoykin2017
Quote from: magpwr on October 28, 2014, 06:50:44 PM
hi Enjoykin,
I may like Brutto drawing of the circuit diagram as you have shown us.
But Brutto have not produced any working device yet.
People are still using 1/4 and 1/8 resonance for this device.I think they are mixing up this with Don Smith device which is base on 1/4 wave. :D
Why isn't there anyone else besides me whom realized for Akula video it's all about the Harmonics or Sub-harmonics.30th Harmonics and 60th Harmonics for new device.
In order to see perfect frequency alignment only 30th harmonics and 60th harmonics is suitable .2 reasons one is to fit within yoke core capability to around 75khz and another fit within air-core capability not below 18khz as mentioned by Akula.
In the old Akula video tela coil tuning video .The frequency derive from his sprecturm analyser is 165khz and another signal is 55khz .
Use the attached Harmonics calculator it reveal "1650900hz" as 30th harmonics for 55030hz.This is to see prefect frequency alignment besides 60th harmonics.
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/dlattach/attach/143853/
This is the last time i will be talking about harmonics.
Yes thank you Magpwr. Very important data from Roman Karnouhov and You !!
Thank you !!
MAGPOWER 203th HARMONIC AND SUB-HARMONIC CALC:
Enjoykin2017
Also important information !!
HOW TO PRACTICALLY DISCOVER AND MEASSURE STANDING WAVE RESONANCE AND MATCH WITH LC RESONANCE ON 1st OR UPPER HARMONICS AND SUB-HARMONICS !!
Калюжин Ю.В. aka юрий61
Дневники охотника за «синей птицей» - Blue bird hunter´s journal -
http://eurosamodelki.ru/katalog-samodelok/alternativnaja-energetika/Kalyugin-dnevniki-ohotnika-za-siney-ptitsey-chast1-2014
Links:
https://clck.ru/A97wu
https://clck.ru/A97yV
** The Blue bird is slang for Standing Wave resonance **
