0 Members and 42 Guests are viewing this topic.
PolaczekCebulaczek
I still don't get it, this technology is geo dependent so mysterious energy from earth mag field is the source of power or its just mixing current with voltage in resonance?
NickZ
   If Roma's device is true, then it would prove that the Earth ground is not where the additional energy is coming from to produce the 4000w output that it can produce. But, as that device has not been verified, will still don't know for sure.
   The "mixing" is not just voltage with current. The Akula/Ruslan devices are mixing high voltage/low current, with lower voltage and higher current. To heterodyne the waves forms from the two different circuits, to produce something else. What exactly that is, we still don't know. As no one here has been able to replicate the amplification effect, to be able to produce self running.
  Most replicators have given up, unfortunately.
  But, it's far from being over.  It's just in it's initial stages, with more to come. So, stay tuned in.
  Possibly the many people being effected by big devastating storms, poverty, and unending wars, may initiate more interest in these types of devices.  But, for now it seams that it's not as easy to accomplish as we had hoped.
   I'm still waiting to hear from Geofusion, as to his being able to self run his device,  not just lighting bulbs connected to a power supply.  His silence lately would indicate that he's not there, yet. Or that he's hit on it, but is too afraid to let us know.
  Time will tell...
PolaczekCebulaczek
QuoteThe Akula/Ruslan devices are mixing high voltage/low current, with lower voltage and higher current.
if its just that (a way of extracting EM energy from the atom) then why its geo dependent? does not make any sense.
One more VERY IMPORTANT thing... maybe we should not look for a massive OU at output, JUST A LITTLE IS NEEDED then self looping would generate/multiply a MASSIVE amount of energy with time, and load is needed for choking the increasing energy, otherwise device will overload and melt! a true overunity device will do that but I'm afraid  that no bulbs would stop constant energy increase rather an electronic component (on off pulse switch or SPARK GAP?) that break for a moment the OU effect.
Quote"This case here is the essence. It holds my circuit. From it depends how much power we get. Now there is little, but it can be expanded infinitely. The nine-volt battery, one only needs to start. But then you get as much energy as you want. "
- Tariel Kapanadze
so maybe Geo is close if he is at 101% efficiency. If his looped device will burn out right after he close the switch then we can call it a success :>
NickZ
  I have stated my opinion many times previously. This type of free energy device has nothing to do with extracting energy from matter (the atom), but extracting energy from the surrounding ambient, as Tesla has also mentioned, many, many, many times. From the surrounding cosmic energy source, and not by poisonous nuclear decay. Which Tesla was never trying to do, ever.
   You'll notice, if you been watching Ruslan's videos, that he turns the device on FIRST,  and afterwards, he turns on the bulbs. He is in no rush to do this, (turn on the bulbs) as there is no overheating, nor anything else if he doesn't turn on the bulbs, first.
There is a reason for that, (why he and Akula turn the device on first, but which I won't go into at this time.
The point is that, NO, the device does not melt down if there is no load. That is not the case, nor has it ever been the case.
But, the bigger the load will help to pull more energy from the ambient, (or even from the input if there is one), but not by burning up matter, (atoms), as you seam to think, but by extracting energy from the air.  Not from the ground, as Roma has shown on his last self running video, while not needing to use any EARTH GROUND, at all. Nor from the negative post of a car battery, either, as some think is needed, as a substitute, instead of an earth ground.
  There is no proof, either, that these devices are geo dependent. Which could be just an excuse, for not being able to make the device work. That has not been proven one way or the other, as yet.  Just because Akula couldn't get his rig working in Germany.
forest
The Earth ground is used only to lower resonance frequency, make antenna longer.
