0 Members and 235 Guests are viewing this topic.
AlienGrey
Nelson there is much more to it than that I feel. Let's look at the electron it's said to be a charged particle trillions are all around us just dormant (doing nothing) that need to be made active by flipping each one so we can use it as energy, we can do that in three ways if we flip it to the left we get a magnetic field if we flip it to the right we get a voltage and we can also accelerate it's potential. Now the other problem is to find a way to extract it.
All this is basic stuff and can be found anywhere on t6he internet
AG
Jeg
Quote from: nelsonrochaa on October 10, 2016, 08:32:53 PM
Hi Nick , hope you are well,
about ground :
ground connection could be "recreated"  with a long wire connected to a metal surface without have any real ground connection , but in other hand the collection of charges will be higher too, if  is used  a real ground,  they will acts like a bigger plate with bigger  surface creating a bigger unbalance of negative charges  in relation to the other plate  , and is the reason to not need long Antenna on that system, because the charges between them must be unbalance.
Connecting one plate of a capacitor to the ground we will get a current flowing in this circuit because electrons from ground plate will be pumped creating excess of electrons in relation to  other plate that will become with deficit of them in other side , creating a potential difference between them.
The Grenade acts like a capacitor plate charged by the Tesla coil  , with a high electric field kick provided by kacher circuit and that create the process to make the pump effect . So , higher the charges collected  higher the current that will flow between ground and grenade lowering the power need on the input system. That process will be where the extra "Power"  or amplification is extracted, but is not the only theme to think in this type of system 😉.
But like many months ago i say , is not the only way to make this effect happens if this process is full understand, and that should be the reason to kapanadze say  their circuit is "so simple you will laugh" .
I see in your lasts answers you are a bit nervous when give your answers, but you should learn that sometimes without any warning our brain could receive a click and everthing start make sense , and to that happen we should make first  sometimes the most basic tests;  could be basic but important to clarify our ideias  about some particular subject .
Nelson Rocha
Hi Nelson. Always good to read from you :)
My question: Is there any difference between positive and negative charges from ground in terms of power? I mean, what is a better practice? Collecting from ground negatives or positives?
Thanks
nelsonrochaa
Quote from: AlienGrey on October 11, 2016, 04:09:26 AM
AG
Hi AG,
For sure have much more to understand then i wrote for sure,  but think with me ; Why start make something bigger and complex without understand some simple clear functions of full equation ?
How many already do the simple test of connecting one side of a cap in ground and kick other side of cap with a  reactive "punch"  to see what happens ?
I could say most of people never tested , and is easier to make that test but even that ...
How many full understand the roll of the bifilar coil that are almost present in every announced "free energy" device ?
Maybe only few , others just use, because someone show that configuration in a "overunity" device in internet , and so should must be good :)
You could find more than is expected in internet , but much of that is true or advantageous to most of us ?
We know that most of this data  is only speculating ideas of people like you or me and we should filter that, otherwise we can swim in a sea of lost ideas forever without visible results.
Some of circuits diagram that run in Internet even real , could not be enough to someone succeed, because even some of that circuits could be real good data, just some details on tune process could make huge difference if we don't understand what real happen, and that could be frustrating, make user think that information could be only a garbage  but just don't full understand all points.
I ear people talk about the theme of Geo localization , when Akula argued , be the reason to fail their demonstration in German .
Someone already think about the the difference of distribution of radon in different countries ?
maybe should think on that , and maybe Akula not lie when talk about that Geo localization problem ,to not have success in their demo in German .
Radon is present in different concentrations in ground and air and could be a source of power or not ?
Food for thoughts
Have a nice day AG
nelsonrochaa
Quote from: Jeg on October 11, 2016, 05:30:35 AM
Thanks
Hi Jeg,
I'm out in last months with some healthy problems but i appreciate hear that you like see what i write  thanks .
About your question :
Power is the rate at which energy is converted from the moving charges , so depending how one point is unbalance in relation to other  "ground".
On this particular system , the process of "kick" with high positive pulse the Tesla coil by the kacher circuit , create excess positive charge that attracts electrons from the ground, but the inverse could be happen to , because if the charge of the "kick" is more negative then ground and the unbalance exist in same way between the two points (ground and top of coil) creating the same difference between charges, attract more positive charges  .
So the circuit should be design in consideration this point's ; long antenna or longer ground  ? ;)
But of course this only my thoughts based in my experience and observation about this particular theme .
Have i nice day Jeg
Nelson Rocha
Hoppy
Quote from: nelsonrochaa on October 11, 2016, 06:19:56 AM
Food for thoughts
Have a nice day AG
Interesting thought: http://www.sgem.org/sgemlib/spip.php?article8220&lang=en
http://www2.meteo.lv/produkti/soe98_eng/texts/radiat/rdt_stt.htm
https://www.euronuclear.org/events/topseal/transactions/Paper-Poster-Abramenkovs.pdf
http://www.nuenergy.org/using-radon-as-a-fuel-source/
