0 Members and 275 Guests are viewing this topic.
nelsonrochaa
Quote from: T-1000 on October 11, 2016, 11:22:22 AM
Hi Nelson :)
The radon is much less to worry about when there are working Tesla coils.
Yesterday within a group (and GeoFusion was guest for a weekend in UK lab ;) ) I demonstrated how Tesla coil can produce high levels of radiation on specific frequency and pulse trains with discharge. The Geiger counter went 4000+ CPM on distance of 2 meters away from Tesla coil before I stopped circuit and was still showing that one minute lafer... That was very close to NMR effect just in the air. So it depends on what you are doing with Tesla coils. It may cure but also may kill depending on the voltage and frequency.
Cheers!
Hi T-1000,
I know about that,  a  Tesla coil can produce high levels of radiation , myself measured  with geiger meter ( https://goo.gl/photos/QvNiStvqYRVu4VHk6) high values  , and i try warning some people some months ago, and in some tests that i did  i get sick because that radiations .
Myself ask help to Stivep some months ago in a PM message to try figure out what happen in that time , because my partners get sick too , even without direct contact with the workshop where the tests are  conducted. Only after some more months after  a figure out what happen .
And that happen not only with Tesla coils but with particular ferrite cores to ... but you already should know that ;) the NMR effect.
The problem is that radon decays to lead-210, a beta emitter,  under some electric disturbance circunstances  and decay to polonium , and that is a bigger reason to talk about that, because could be very danger much more than that radiation that you measure in your tests and you describe.
What i sugest in last post about Geolocalization justification  gived by Akula to fail in their demostration  in German , could be because a low concentration of Radon in  most of German .
And Radon could be used like a fuel .
Hope i clarify the theme about Radon and the factor of Geo localization.
Cheers
Nelson Rocha
nelsonrochaa
Quote from: NickZ on October 11, 2016, 10:21:39 AM
   Nelson:
   It's always a pleasure to hear from you.
   Although what you mentioned does resonate with what Tesla has written concerning the negative charge stored in the ground, and positive charge found in the air.  I'm wondering why Roma (video below) does not need any such ground line, at all, and his device can still produce as much output as any other self runner, which need ground lines to function. Nor is it dependent on geo/location to do what it does.
   I've done the tests using a capacitor connected to the ground also, and found no benefit, nor increased output from my device.
   What we need are specific and exact build details, not just more ideas, or hints. The thread is full of ideas, but, still not a single self running device.
   Have you changed your mind about letting us know about all the more important details of your self runner?
As that is what we really need. And also, have you been able to increase your output compared to what it was a year ago?
   https://www.youtube.com/channel/UC8fOJbjueHyD8BbUigXubmA
Hi Nick
Concerning what you tell :
1- Tesla talks about the ground, be a vast reservoir of free electrons did not say that ?
2- You did the test with the capacitor , but in what condicion ?
I did not tell  to connect your device to the capacitor . I  sad to connect  one side of a cap in ground and kick other side of cap with a reactive "punch" . Is reactive the nature of your kacker ?
I think not ..
What cap you use ? A small value could make huge diference in tunning process so how you could say just because you dont see the  effect that  not work :).
Geo already show one time in their shots how could be trick the tune with caps in a resonant circuit and about their values , but i left you a shot where you can see that even small value could change all the scene .
https://www.youtube.com/watch?v=_YIuUrubUfQ
3- No I did not change my mind about share how works that circuit, and my intention never was talk about them , but talk about some aspects that could be interesting to some people , and i really think when i write last posts that you could be one of that persons but seems not ....
If i decide share details of that circuit will be better i open a new topic because some aspects of circuit are diferent from what is treated in that topic .
That circuit that you talk is used currently only  to study  some aspects and make demos  , i  already made other new circuits to diferent  type of applications.
And yes i already managed improve the output, but have other aspects that need be worked to to respect some rules of EU market .
If you have interest you could see some new vídeos in my channel with that specific circuit showing  operating without feedback,  connected to a power source  to show  measures between  input vs output .
https://www.youtube.com/watch?v=v5J0jy-ukcY
https://www.youtube.com/watch?v=N3CjCNeH8rE
cheers
Nelson Rocha
PS . the link that you share is not available anymore
dewetw
verpies
HF High Voltage interferes with the operation of Geiger counters, so there is nothing unusual about that.
...and was still showing that one minute later...
...however elevated Geiger counter readings, after the HF HV circuit was stopped, is unusual.
stivep
Quote from: Enjoykin2017 on October 11, 2016, 11:52:56 AM
PolaczekCebulaczek yes you are right my friend.  Real "energy" extracting comes from atomic shell (electron multy layer grid - that means comes from sum of mass electrons), which exist at very high altitude from the atomic core. How it look like: If an electron diameter is 1cm than distance till the atomic core is 1km. These are real experimental data obtained by E. Rutherford - i have only zoomed by factor 104r-105r to show you how it look like in realm.
Also you should know that in couple recent years, more than four hundred particles with a charge smaller than electron charge are found (crashing electron`s mass by accelerating and deccelerating collisions), and that mean, an electron charge is devisable - shared between many sub-electron particles.
So we have his Majesty - An Electron
I will repeat his main attributes::
1. Giant density = 15 000 ton/cm3,
2. The negative charge which can be shared among sub-electron-particles
3. Very strong love to magnetic force lines.
Most of all these facts give construction of an electron using some healthy logic statement:
At center of an electron — the strong magnetic mass (atomic core weight), and around it has stuck  several layers of elementary particles with electronegative mass, retained by attraction forces of atomic core mass.
At an outside layer electronegative mass, charge field of outside layer has not compensated by attracting field of central mass (atomic core weight), therefore this composing full-sphere behave like negatively charged body.
Forces which retain parts of electronegative matter are quite different in magnitude — for example for the first layer force will be stronger than the last outmost layer by 4 orders of magnitude.
Lokk with the mind  - central core mass , highly attracting core`s force fields at big distance order 104-105 r,  multy grid layers of electronegative matter with multy layer`s nodes setup in all repeled mode caused by strong Coloumb forces.
Now look - electronegative matter was trapped. Can`t fall in the atomic center core,  nor can run as fast as her's legs will carry her. As result we have pure balanced composite sytem of several forces with immense potential power (Coloumb power) concentrated in whole electronegative matter at distances 104r-105r from the central atomic core.
Now is clear where come "power" coming. Power in sense of Giant Kinetic Field released once we have disturbed intrinsic force fields balance (both of them - atomic core force field and outside layers of electronegative force field.
I hope you can understand because it is very simple. And MUST BE SIMPLE because the mother nature does not like complexity like human beings does.  :D
Well it is a 1st part of Show called "energy extraction" precisely will be Kinematic Mass Extraction because only the mass can bear the force. I dont know other case in nature.
Now about 2nd part of show.
If we realese "potential power" trapped in inner sphere of an electron what we will get ?
How it is possible ? Taking in account that central mass of an electron is 5 orders of magnitude densiest of an elctron - which i repeat have density 15 000 tons/cm3 and taking in account additional minimum 4-5 orders of magnitude stronger Columb force in intrinsic electron volume can you understand with what kind of Giant forces we have a deal accounting great number of electrons in multy layered grid of an atom. But it is not elese the end of show.
If we go further in matter organization what will be with forces in sub-sub particles (most inner sphere of an electron) and what will be with their immnse density by additional 4-5 orders in magnitude extent. But it is also not the end of show.
We going further and further deep in force and field matter untill hit Mather Nature Threshold of matter and force organisation. So we will come to some primary particles wuth so immense density that they can not be shared on much smaller particles because simple they does not exist further.
And now according to some hidden Vedic Cosmic knowleadge that primary Natural Threshold level is at *7 *seven* layers deep at Matter Realm until we hit primary source - primary partilce matter.
I must to admit i can imagine in my mind such giant immense densities and forces of Mother Nature Matter organisation. Remember Tesla´s rule in his MFT - Mass of Primary should be equal Mass of Secondary. Why should ?  ::)
Does the so called "Aetheer" exist and where to search ? I think Yes Aether exist not outside matter, in so called "empty space - vacuum" but in matter essence. So simple. And more there exist sub level of Aether known as Astral levels, further Astral exist Mental level and so on till the top 7th level in Matter Abyss Deep.
So all i have said - it looks like that an ordinary human being have potential possibility to rule whole Universe because that same Universe has "pack up" such possibility in every human being with high evolutionary consciousness - simple because only such super-human or super-consciousness can control such immense cosmic forces. So need boost our consciousness in Matter Abyss Deep.!!
I think it is a RIGHT WAY ON THIS PLANET HUMANKIND should go if want exist !!  :)
Reg.
Enjoykin
Enjoykin
I'm giving you  first  warning. Stop trolling on this forum.
You may post if you have question  or try to add something valuable.
We have had Russian trolls before on this forum And they are  pretty quick gone now,
But it is not important what Troll is from.
You are adding  garbage to the pages  on this forum ,
I have made comment already about  Russian Trolls paid by Russian government.
( read my post from before)
If you continue than I'm going to ask Stefan to remove you from this forum.
Wesley
PS:
You are very  young  individual with good English skills.
I  just spoke  about you with former Russian troll who escaped to  New York two weeks ago.
His advice  for you, is
1. to use as  evidence your hardship  and lack of choice and persecution by  Russian regime to support your  claim rights  for asylum.
2. try to  collect as much as possible of evidence as you possibly  can.
In USA  refuge      gets  from the very first days full  monetary( social) support ( shelter and food)
3. refugee program includes free education .
A Troll from Russia gets  as little as $70 per month, you can get easily  even $40 per every hour for  work  in a profession of your choice  and you will still be entitled to refugee program.
Think about your future- 3 years from now you  may earn around $50 000 to $100 000.
Trolling for  that biggest pig in Russia does not make Troll to advance.
