0 Members and 79 Guests are viewing this topic.
AlienGrey
Quote from: verpies on October 13, 2016, 07:43:12 AM
Below is a good video that show how to "increase" Amps in a circuit with a high frequency 10VPP signal:
https://www.youtube.com/watch?v=DVXPGj0Pjyc
Fanks Verpies a good laugh !
Hoppy
Quote from: AlienGrey on October 13, 2016, 07:41:30 AM
Come on then Hoppy emulate the circuit and make the experiment ! you will need a VERY HIGH VOLTAGE  SCOPE PROBE or  it will destroy your scope. I think it's just a self oscillating relay and a Stiffler 2 diodes and a cap charger circuit where he puts an earth to the neg of the diode and the cap, then shorts the cap out. It's so simple even you can do it ;)
I'll leave that experiment to you Alien, as I'm out of Stiffler 2 diodes.  ;D
NickZ
  Alien Grey:
  Are you afraid to do you own tests, to prove your point?  Why suggest your ideas for someone else to do?
   I worked on three different forums on the Dr. Stiffler tests...  Until he stopped those tests, and was onto something else.
   He could only light a few LEDs, while using a ground connected to his test gear, and never used an outside Earth ground.
   The capacitive leak from the grid's ground connection is enough to light leds, which I showed in one of my videos.
   Dr. Stiffler never took anyones advice to perform the tests outside, while NOT using a ground connected from the grid.
He thought that he didn't need to do that, so he never did. Nor did he turn off the breakers at his power meter, at least. Like I did to show the difference.
AlienGrey
