0 Members and 140 Guests are viewing this topic.
NickZ
Quote from: MenofFather on October 23, 2016, 03:56:37 AM
You asking, why he changed wire? Or why winding is diferent? If about winding, then he explain, that that better, then wave gose to one direction.
   Does he explain why changing the windings can make the AC signal change to go in one direction (DC?)?
   Does any one know how to make the Kacher's output AC signal go in one direction, to the antenna coil?  So, that we have unipolar HV DC pulses, instead of AC pulses?
   Isn't that what Tesla had mentioned is needed, instead of a HV AC pulse?
Tomtech29
Quote from: beboszek on October 23, 2016, 06:58:30 AM
Hello,
This summer I assembled high power nanosecond generator based on DSR diode and saturable core, which was discussed on this thread some long time ago. Because this circuit is not so obvious, I created short document with all data needed for building such a device with common elements. Also short theoretical explanation is included, as well as tuning procedure. I wrote this paper mainly for myself not to forget this interesting circuit, so it is in polish. For those interested in the field it should not be so hard to translate it.
document is here:
http://beboszek.xyz/elektro/generator_nanosekundowych_impulsow_duzej_mocy.pdf
PS.
Publication of Ukrainian self-runner last week mobilized me to dust off my setup, so I'm back into the game.
Cześć Marek Mam pytanko podczas pomiarów, impedancja obciążenia 50 Ohm to na końcu kabla "coax" rezystor ?
Dzięki za wstawke.
beboszek
Quote from: Tomtech29 on October 23, 2016, 10:44:48 AM
Dzięki za wstawke.
Inductionless HV resistor connected directly to the output (diode terminals)
beboszek
Quote from: Utopia Now on October 23, 2016, 10:15:23 AM
Hallo Marek,
Very inspiring your  work  in the pdf  2000 volt in 50 Ohm at a rate of 35kHz  .
Thanks
AlienGrey
