0 Members and 1516 Guests are viewing this topic.
T-1000
Quote from: verpies on November 03, 2016, 09:21:54 AM
I don't know what role these nanopulses played in Dally's device described in the beginning of this thread, but I read some plausible theories (e.g. here).
I don't know what "flipping the flyback pulses" means or whether it is desired.  I don't know if nanopulses and flyback pulses are interchangeable in some sought after effect or if one is supposed to modify the other.
Phase relationships are important but not in all scenarios.
Do we even have a complete schematic of the recent Adrian's device or its Modus Operandi  or at least its tunning instructions?
The nanosecond pulses which cause current in the grenade coil are realistic power.
The relationship between that and transformer action from induction circuit current defines output power.
The question still remains if the current caused by nanosecond pulse+ions electrostatic flow charge of the coil as capacitor and mixed up with current from the induction circuit is what is causing more output power than power spent from the input source in closed loop circuit. Which ends up as open loop system.
Cheers!
NickZ
  T-1000:
  Now that I found where the "interuptor transistor" is located on the Adrian Kacher circuit. Please let me know how the transistor is supposed to be connected to the rest of the circuit. I've placed Ruslan's diagram, modified by Geo a few posts ago, and again below, so that you can show me on that diagram how to connect the transistor, if you know how.
  Although he is running his device without that transistor being connected up, I'd still like to try it out if possible.
  Do you know what type of transistor is to be used, also?
T-1000
Quote from: NickZ on November 03, 2016, 10:00:33 AM
  T-1000:
I would expect the signalling like in akula katcher cicuit. The katcher circuit fires there on push-pull mosfets dead time which is very short period.
Will see soon in the lab if this assumption is correct...
Hoppy
Quote from: AlienGrey on November 03, 2016, 06:14:07 AM
with respect Hoppy I don't see you observing or doing what you ask others, no offense intended.
Alien,
I've already done this with the device setup I had way back at the beginning of this thread, which is why I suggest that its important to observe and measure the things I've been talking about.
GeoFusion
Hi Guyz,
I will be uploading a recording soon today with requests which I saw on forum.
but first..
   Nick,
Quote from: NickZ on November 01, 2016, 11:30:53 AM
   It's just a simple Kacher circuit, conico, without a duty cycle controller.
I'm just trying to keep the input volts from going too high to it.
   Geo: Can you explain a bit more about the "interuptor" transistor, and how to incorporate it into the Kacher circuit?
   I know that you haven't tried to do it, yet, but, any info on it would be appreciated. You can PM me if you like, I also use whatsapp, and Skype.  I've called T a couple of times, but he has not responded, yet.
   I also used a "tone generator" and I can't hear the frequencies of 25Khz to 27kHz. But, I can hear yours, and it's the same as the tone generator running a tone of 6.98kHz.  So, I'm still interested in finding the differences. A current pic of the scope shot, would do.  BTW: do you have a scope, or can borrow one?  If not,  don't worry about it.  It's just a curiosity of mine.
As I'd like to run at a similar frequency, of both grenade and Kacher circuits for comparisons to yours, and to apecore, also. As we have similar somewhat similar set ups of the Kacher/grenade coils system.
  Yes, I know about the TL494, and will go that route, in the future, no need to convince me, I'm already aware of what it can do. However, so far,  I've been able to replicate most of the same "effect" that you are showing up to now, even without it.
  The feed back path is now the tricky part, as well, which is also what I'm dealing with, in the simplest way possible.
For me, simple is what I'm looking for.  Hopefully with commercial controllers that will do the trick, instead of homemade.
Well, I have a file below which will have HD pictures and could Zoom In to see the device of Adrian
very up close and see that there is one more element onboard the kacher.
He does Have an PWM board it's underneath the wooden board where Pushpul yoke is connected.
My lastest diagram.
About Interrupter,
well for what its purpose for in these cases is for us to focus on Collapsing field in pulses.
Abrupt Shut off on kacher/ Tesla, that is where we all need to start. This is where it will call :)
Arunas has pointed this out many times and for what Akula told him and told me and it's all true.
He has provided schematics which can be followed and should try. this is for everyone.
for the Self run I will need about just a bit more Juice being harvest from the backround and
It will. because voltage at where I connect that bulb is not in range yet to self run and maintain yet,
needs tweaking. Yes I do have a PC Scope which I use to measure and check.
Yes you will need a TL494 or equiv. You will see difference immediately
Btw kacher also has to be tuned proper spot on the potentiometer, to configure best voltage givin.
See below I have my lastest Diagram, Discard the old one.
  Jeg,
I am not sure yet if the mediator yoke which has impact on input amount.
But what I can say is, without the mediator, my device will not funtion properly.
There will be no Synchronization in my system if mediator is removed. will not go in phase.
If you try to connect without it, Yes, you can have Kacher working alone and Pushpull alone
but not in phase, and Instead of amplifying it seems to want to decrease output without it
or just not working.
The video that I will be posting soon will let you also see what happens if I let kacher only drive.
You will see that kacher is also not pulling much, It might look the same amount when
pushpull is running on it's own. maybe about close to  1 amp. both of them if drivin each.
It's when combination occurs with Mediator and the resonant caps are activated
that is when 4-5Amps kick in as a standart which will stay,
It can Fluctuate few mili amps. but nothing more than that.
I even did hook the Ground wire to a 12 Car battery which is a bad one, which has fluffy charge
( does not hold charge ) using minus as ground. but you will see funny differences.
that will be in video  ;)
Hoppy
I will show some scopes shots soon to show what Is happening,
But what I can already say is, You see a Sinus and when in effect you see a thick Snake ;).
Utopia Now,
if that is your grenade's frequency,
now try to wind kacher on and let it resonate on those freq ranges see what happens.
I my self will be winding a second one on Specific meters soon.
All,
This video here is on the web.
Adrian G is explaining his device, showing a bit up close but low resolution.
It's here I think ppl will know what is missing.
Would be nice for Wesley to translate but, permission is the thing.
https://www.youtube.com/watch?v=0qCl0TKcku0
    Cheers~
