0 Members and 104 Guests are viewing this topic.
conico
NickZ , on page 1040 i give you a movie with what Adrian diagrams use.
You can see there he use Stalker's diagrams and he use IRF840 or 2sk2611 a mosfet not SC 5200, , his primary of Tesla coil have 14 turns.
For Geofusion i have a question,  how did you start to wound the Grenade coil cw or ccw, First turn of your grenade coil is in what direction, cw or ccw?
Ed morbus
GeoFusion
Quote from: conico on November 03, 2016, 11:05:48 AM
You can see there he use Stalker diagrams and he use IRF840 not SC 5200, , his primary of Tesla coil have 14 turns.
Hi Conico,
Grenade first layer and second layer are the same, is wound CCW,
the rest 4 layers are all CW wound.
see Diagram below,This exact winding directions on my bench.
verpies
Quote from: GeoFusion on November 03, 2016, 10:15:20 AM
I am not sure yet if the mediator yoke which has impact on input amount.
But what I can say is, without the mediator, my device will not funtion properly.
There will be no Synchronization in my system if mediator is removed. will not go in phase.
If you try to connect without it, Yes, you can have Kacher working alone and Pushpull alone
but not in phase, and Instead of amplifying it seems to want to decrease output without it
or just not working.
What I would like to see is how the distance of any HF electric fields (e.g. Kacher)  to the mediator and push/pull transformer affects the O/I power ratio of your device and how it affects any scopeshots you have.
...and of course, the more scopeshots you post, the better .(with probe positions described)  ...especially the ones made by the method Hoppy has suggested.
Hoppy
Quote from: AlienGrey on November 03, 2016, 10:47:17 AM
no  I don't have any equipment to do that. but its more than i'm putting in. (it's up in the mhz). If I put a large value smaller cap on it will start to get warm and it will self-charge a lead acid battery, I did a video but some yank started to arse said he thought of it first. Oh and the PSU earth was disconnected to the PSU.
Thanks Alien. You don't need the PSU earth wire connected to get a good bang on the cap. The neutral is good enough.  ;)
