0 Members and 281 Guests are viewing this topic.
lacphong
Hi Utopia,
Thank you for sharing your coil's specs.  I'm trying to understand the relationship between all these different frequency, but they just don't make any sense.  :o
Quote from: Utopia Now on November 02, 2016, 07:50:36 PM
Hallo Lacphong
My Grenade Coil resonates at about 1,5 Mhz   see video https://www.youtube.com/watch?v=_uDusLU5IPQ
But it depends on how i measure it ...  if  I have the osciloscoop probe set on x10   the freq is about 1,5 MHz ,  if  the probe is set on x1  the freq  is about 1,3 Mhz.
In the video i pulse the eciter coil  with a square wave from the function generator ... see text  under the video.
lacphong
Thank you for your information,
For some reason, it just doesn't feel like this is the right way, because like designing a Tesla coil, frequency is very important.  We can't just wind the coil a certain way and size, then expect the specs to be correct.  Even when building a Tesla coil, we have formulas to do all the calculation in advance, but in the coil always need some fine tuning at the end... That's why I would like to know the relationship between these coils... I think Akula revealed the secrets in his video, but I'm having a hard time understanding what he was trying to says because I don't know Russian.
I've been reading through thousand of posts in this forum, there are so many ideas and theories but none seems to work so far.  I'm trying to put my own ideas together, from reading all these posts and watching Akula's video..  :D
Quote from: NickZ on November 02, 2016, 02:01:46 PM
   Lanphong:
   The coil winding ideas and specs come from Kapanadze, replicated first by Akula, then simplified and re-replicated by Ruslan, and now by some other guys, also.   Each one is showing totally different running frequencies. So,... who will you trust???
   As I see it, the main resonant coil is the grenade's 37.5m output coil, which needs no tuning if made to correct specs.
The grenade's inductor coil/yoke coil LC circuit and push-pull is adjusted to best sync and provide the highest gain with the grenade output coil, not he other way around. The Kacher is then tuned by adding or removing turns. Then the tuned Kacher is made to sync with the 3t coil/grenade induction coil circuit, once that induction circuit has also been previously tuned to the grenade output coil.  The grenade output coil will be running at that same frequency as the Kacher induced/ grenade induction coil, when the power is switched on.
  The amplification "effect" is noticed when the Kacher's output is added to the induction circuit's output. Or not noticed.
   Your trial and error method...  Might be the best way to go, in any case.
   We are mostly trying to replicate the Ruslan type of self runner, as in the video TopRuslan 13.  As that is the simplest way to go, so far. And so far, it's been working out to the degree that we've taken it.  Looping is the next big step.
verpies
Quote from: AlienGrey on November 04, 2016, 12:36:43 PM
how can you be sure it's not ?
I can't be.  Especially without I vs. V measurements on that wire.
Have you tried it with AC mains, did it work ? and what about a trying it with an ac/dc motor the type with brushes, and you can't, do you know why ? Ad yet it produces loads of free energy you can't use. ;p
I haven't tried, but this guy seems to have tried it all and gave up.  What was wrong with his attempts?
AlienGrey
Quote from: verpies on November 04, 2016, 02:14:52 PM
I have seen one Russian guy in a video where he is in a field miles from everything and he has a clamp meter it's measuring 3 or 4 amps around the pipe, when he disconnects the earth it dies, till he starts it again, take what you will from that.
Watch this  https://www.youtube.com/watch?v=PW7mwcLk9PM
Hoppy
Quote from: AlienGrey on November 04, 2016, 02:44:01 PM
As has been said before, not a sensible measuring device for this type of device.
