0 Members and 623 Guests are viewing this topic.
Hoppy
Quote from: beboszek on November 08, 2016, 01:23:44 AM
Capacitive coupling may be the issue here. That is 10^6 Hz frequency range.
Yes, for high frequency current from device to ground.
Jeg
Quote from: Jeg on September 02, 2016, 05:47:48 AM
In relation to which is the right moment to fire your Katcher: When in series resonance, voltage and current are in phase. That means, voltage across the 3T coil (which is the power supply) is in phase with the current that flows around the series tuned circuit. Voltage across the in series capacitor, lags 90 degrees from current, and voltage across inductor(25T+25T) is leading 90 degrees from current. So it is a matter on what voltage of the above you compare with current's phase. So if you probe capacitor's legs, the current peak is 90 degrees on your left, there where capacitor's voltage waveform meets the zero line. If you probe 3T coil's voltage, then you should fire just on the peak of it.
@lost_bro
AlienGrey
Quote from: NickZ on November 07, 2016, 09:25:43 PM
  Using a car battery on a table as the virtual ground shows that there is NO energy coming from the ground. Or not?
If you think that go over early Tom Brown Eric Dollard vids from border research electronics any mass can be an aerial or earth but earth is the best as your building a zero foundation.
And the spark gap thing !
NickZ
Quote from: conico on November 07, 2016, 11:59:22 PM
I do not know, might
all I know is that Katcher has little power, no more than 1000V to the antenna but if the food inductor has the effect of amplifying 5-10 times for antenna, see Geofusion's last movie.
I reached at the resonance frequency and are only 2V the extra load like Itsu, in one of His movie.
Hi NickZ, a strange way to show is nothing on the ground wire.
https://www.youtube.com/watch?v=Dh4xTLEwI6w
  Yes, conico.  Roma didn't need to lick the ground line like TK's son, as he doesn't even need to use an earth ground. Ha!
  Nor a virtual ground from a car battery.  So, nothing is coming from the ground.
   With your 24v PS, you should be able to produce up to a 1 centimeter streamer, without any induction circuit going, also.
  IF not something may be wrong with your Kacher circuit, choke, etz.  Try some ferrite pieces inside the kacher pvc pipe.
   Verpies:  You were wondering just how and where the HV is affecting the induction circuit, If it was through the yoke core or something else. The answer is that Without the Earth ground connected, the HV from the Kacher is running ALL OVER the induction circuit, and going all the way back to the PS, without the use of a protection diode at the PS.
That's why the earth ground is important to use in these devices.
Verpies, and conico: Please watch:
  https://www.youtube.com/watch?v=E--AZUoNowA
T-1000
Quote from: AlienGrey on November 08, 2016, 05:18:06 AM
The spark gap in Sergey board on Tesla top load ("antenna") is doing same voltage limiting and abrupt discharge like in akula's basic circuit. This is important bit for achieving required effect if electronics cannot do it...
