0 Members and 243 Guests are viewing this topic.
verpies
Quote from: GeoFusion on November 18, 2016, 01:42:00 PM
The Effect,
Ions within the electro static field excited and pulled by telsa/Kacher/antenna that will merge ( go in phase) with the resonant magnetic field of inductor which will create a higher output power combined out
within grenade in capacitive form. ( the receiver.. Grenade)
That's all fine and dandy, but notice the the "electro static field excited and pulled by telsa/Kacher/antenna" in your scenario is affecting the inductor (including any cores in it).  That experimenting avenue might deserve some hope, since not everything is known about such interactions (especially HV affecting ferrites).
However the HV or "electro static field" affecting the gate control circuits is an undesirable influence, that just makes the entire circuit unstable and unpredictable.
Also, from experience we know that MOSFETs are not capable of making any free energy no matter how you abuse them.
Collapsing the field of HV HF or better to say abrupt collapsing, is what causes this energy to be called in,...
It still makes sense to experiment with HF HV acting on inductors (especially cored ones) because not everything has been discovered about these interactions, as evidenced by that IEEE article by Konrad and Brudny
But experimenting with HV acting on MOSFET gates does not make sense, because everything has been discovered about them already, including the fact, that gates do not generate any free energy, ...just free profit for semiconductor manufacturers when you zap them with HV.
If you want to synchronize the phase of frequency of the gate signals to some other component of the device, then design for it deliberately - without relying on random HV interference on the gate circuits !
apecore
Verpies,
Thanks again for the statement about imunisizing the gate and other HF/HV interference.
Also i appreciate the way you comment on the facts...it is really added value.
Guys, it is not ment to be dishonerable to all of you giving input... in what way ever.
I only hope that we stop running around in this circle where we are in for at least 50 pages or more.
Why not act and proceed on these statements/comments as Verpies is making?...Which could be made in practical solutions by Hoppy etc..
We bench people we need the engineers to solve our problems...or at least feed us with facts so we can validate our results......also we need people as Hoppy to challenge a of us.
We do have a Golden team ;D..
Lets do small steps and make sure we can confirm the result so that it makes us move on instead of circling around.
I hope you all understand what my feeling is about it all and i hope we can play the game together.
Practical...i think Verpies did defined some small steps in his latest comment on Geo post.
How can and should we proceed on that?
NickZ
  Over voltage on the mosfet gates is not every ones problem, nor the only cause of component burn outs. I don't see any of these problems on my own set up, nor excessive heating of the fets, either.
  I don't think over voltages on the gates are the way to achieve free energy, at all. Nor do I see any one else thinking that as well. So, I don't know where Verpies is getting those ideas from.
  If anyone is seeing over voltages on their gates, this does need to be addressed, of course, but the circuit and snubbers to avoid this from happening are already known, and posted, if people would just follow the schematics. Yet no one does, and chose to invent their own snubbers systems, instead, which may cause these types of problems.
  Now if you're still getting too much voltage, and amperage as I am now seeing on my Kacher circuit's input, that does require attention, or some things will go up in smoke, sooner or later.
   Experimenting and testing the effect of HV and HF on the different type of coils, (with or without ferrite), and their interaction on the magnetic induction circuits, is what this is all about. And, Not about cooking your fets to produce free energy,
or "relying on random HV interference on the gate circuits !"   Which no one is "relying on", nor trying to do, purposely.
Meta
"Collapsing the field of HV HF or better to say abrupt collapsing, is what causes this energy to be called in,..."
You bench people need the engineers but you also need me, to show you reality.
"Abrupt collapsing" is exactly what happens in an atomic explosion. The atomic bombs were devices that drove symmetric and concentric wedges of explosive material into a center. This center experienced an "implosion". This implosion tore the fabric of space, leaving nothing in it...a empty hole/vacuum in space. Space cannot abore/stand/endure a vacuum, so it rushed more space energy into the vacuum to fill it up, instantly. As the space filled the vacuum, instantly, it looks like it "exploded", as the blast outward.
The energy "called in" is space filling the vacuum.
One more fact and you're on your way.....
You cannot store this spatial energy. You must use it immediately, therefore.....
Rather than try to store the energy, just repeat the abrupt collapse process using, for instance, a method Tesla used.... a spark gap.
Good luck. You're lucky you didn't ban me completely.
NickZ
   I don't know about that.  The banning part, that is.
   I hope that your suggestions are what you're working on, to prove your point.
   I'm still getting PMs from Enjoykin. So no, he is also not banned completely.
   "One more fact and you're on your way..."   Really, that's good, but are you on your way?   ???
