apecore
Quote from: Hoppy on December 03, 2016, 05:23:57 AM
Nelson,
As I pointed out at the beginning of my post, I just deduced or more accurately guessed the function of some components. This was primarily in the hope that you would respond by correcting me, which you have and I thank you. It is now clear from the further details you have given us that you do appear to have something rather special in those boxes! I apologise for coming across as being over critical but I am of the opinion that if a device is important enough to demonstrate by video, then it should be done in such a way that viewer understands what is being shown, at least the function of each part / module of the device and where measurements are being taken from. Unfortunately, your video did none of these things.
I wish you every success in your venture.
Hoppy,
I think you did the right thing to apologise to Nelson, i thank you for that.
Indeed your approach was to critical....  even not fundamentally (with respect to your profession)
This was not the first "one track "batterie conclusion you made to Nelson. You could have  known how he would react.
But even with that in mind i believe your intentions are wel ment,...  at the end we all looking the same goal.
Isn't it?
So i think and hope as many of us perhaps do, you will improve yourself in the future speaking out these kind of "jumping to batterie conclusions"
Not saying that the batterie discussion must go of the table,..
I would suggest to put it on the bottom of the agenda.
As it would come out after time and questions, research will point out that thats the only case is left.
I hope you understand that this is not ment personal but in favour of our journey
Greetings
Hoppy
Hi apecore,
Of course I wish the same outcome and hope that Nelson does eventually see the inportance of open sourcing a device that can truly amplify energy. Although I make no apology for crticising his approach to video demonstrations, I do accept your comment that the battery conclusion should be toned down.
apecore
Quote from: Hoppy on December 03, 2016, 09:46:23 AM
Hi apecore,
Of course I wish the same outcome and hope that Nelson does eventually see the inportance of open sourcing a device that can truly amplify energy. Although I make no apology for crticising his approach to video demonstrations, I do accept your comments that the battery conclusion should be toned down.
Hoppy,
I understand your point and i agree in case of video presentation there is more effort to be done even with respect to Nelson's third party aspects.
Hopefully this will also lead to a higher level.
I think this subject can be closed now.
NickZ
   Thank you Hoppy, and thanks to Nelson for showing his considerations on this issue.
   I hope that now we can go on to bigger and better things, such as finding just how an incandescent bulb can be lit with only 6 watts.
   We can hear that when the relay kicks on there is a much higher frequency ringing sound, compared to when the second oscillator is started.  I could also detect more than one frequency peaks on my audio analyzer, as well. Now we know the reasons why.
AlienGrey
If you just want to do this.
Quote Nick
is all you have to do is raise the voltage and pulse the bulb with it. It's been on other forums , has that trick
, the current draw goes right down.
ok
