0 Members and 43 Guests are viewing this topic.
lost_bro
Quote from: apecore on December 19, 2016, 12:07:50 PM
Hoppy,
Again i agree...makes it all hard to get but even more fascinating.
Little steps.... confirmation.... and move on to the next step..
Must be possible with all those guys here.
Also....i have to re post my last post..
Posting and driving car is not a good combination.
Conico's schematic shows us a kacher interuptor not a 1/2 period eliminator.
Greetings
Good day Apecore
Yes, it appears to be an interruptor for the Karcher Transistor.
Also please note the double parallel diodes circled in  Yellow.  It seems to me that they are drawn backwards, have placed corrected diode position to the side.
These are the diodes that Ruslan spoke about having the effect of removing 1/2 sine wave, (half-wave rectification) from the *output* of the Grenade.  In effect if the output from the Grenade is not a sine wave(neg.half period removed) then the HV discharge from the Tesla Antenna (extra coil?) cannot affect it (removed neg. half period of sine wave).
take care, peace
lost_bro
EDIT:  just added another diagram from last year.......
What is the actual configuration of the Grenade windings?  Please note that the attached diagram does NOT coincide with the other attached diagram.  Seems the input/output has been moved around.
Please advise.
GeoFusion
Hi guyz :)
Currently Uploading  videos..
But first
   Aprecore, Conico
If you look closely at that diagram you posted of the Ruslan device,
see those two diodes with kathode going to yoke? on the blue trace
and then to first layer of grenade? use that method
THAT already is blocking 1/2 peroid.... inhibiting negative period of Tesla.
Only simple kacher is needed already and it can be done and does not need to be strong kacher/tesla.
Some good guyz managed this and even in other odd forms which will get shared soon.
Lost bro
Yes all values have to match. Indeed a puzzle.
Most important I could say is how you do the coil lengths for both Tesla and grenade.
after that what happens with Caps to resonate with will go automatic which we already know how.
I stress more on wave-length in comparison with Frequency matching.
In the by the time I used the caps in between the coils was using what was givin on schematics...
but then after used calculations to get what is needed till max on what I could on My Blue Grenade is
the results you all saw up till now, but now it's time to finish it. correctly ;).
My second setup is being used with measurements ofcourse.
Diodes which are used are to kill 1/2 period of tesla.
The Ruslan way, as example is what conico uploaded, see the two diodes on blue trace,
I linked the video on previous posts that it works but By then I had no idea on
how coils need to be correctly yet but only on my ways ;). but was close.
On the other hand, like Akula schematic and which Ruslan did after too, was making boards
which already cut off negative 1/2 period. Train pulses were added for more gain
so there more then 1 ways to do this.
Be creative. :)
Experimenting time is needed
One more thing, Make sure when you have tesla secondary correct, make a ground cable at the same
lenght. has to be tuned to ground. even the ground he uses Diode to block negative halve. ;)
Edit* I personally do not trust that diagram which is  called Grenade question.
parallel cap at yoke is not right. and we are not sure there the halve period is blocked by looking at the setup.
But the way how the grenade is hooked up with yoke seems to be the correct way.
Btw Leave the Diodes reversed. that is how I did and worked.
Time to continue
  CHeerz~ ;D
lost_bro
Quote from: conico on December 19, 2016, 03:07:05 AM
Look for diagram ''Topruslan 8'' is a mosfet for supply Kacher or in Topruslan 8A is a mosfet near 2SC5200 for drive it.
About terminals of the coils ,there is no problem. If Ruslan establish the resonance with this long terminals he must keep them not cut the terminals.
Good day conico
Yes, I agree with this statement;
So,  If lead length is calculated as part of the wavelength to give the Fres, then it must be used as is which now brings us to another interesting point:
Quote from: Geofusion on December 19, 2016, 03:07:05 AM
..... you have tesla secondary correct, make a ground cable at the same lenght....
2Mhz; Lambda/4=37.5m @ Wave Velocity 300Mm/s;
Quote from: ruslan
Land(wire) is also half-wave of 37.5 = 18.........
see attachment below.
so,  @ 2Mhz; Lambda/4=37.5m / 2= 18.75m.
and since;  Length Groundline = Length Tesla Secondary = 18.75m also for Fres @ 2Mhz;
If I remember correctly, it was also mentioned that the entire wire length of the combined Grenade, Groundline, and Grenade Yoke windings including interconnecting leads should measure Lambda/2, which @ 2Mhz = 75m.
take care, peace
lost_bro
NickZ
  Geo:
  You mention: "If you look closely at that diagram you posted of the Ruslan device,
THAT already is blocking 1/2 period.... inhibiting negative period of Tesla.
  Are you using those two mentioned diodes, if so which one are you using?
  Can you show how the Kacher secondary is now producing only 1/2 sine wave, due to those diodes? That would be of interest to see how that is working out. As neither apecore or myself have seen that. Maybe you can show how it works that way, in one of your videos.  As I can't see how those diodes on the 28t coil, (in either direction) can cause the KACHER to output 1/2 sine wave.
  Conico:  The diagram that you are showing at is an old one that Enjoykin posted in 2014, there are updated ones which are showing the circuit only using the simple Kacher circuit, such as the one below.  It's easier to replicate, than the Enjoykin one, and is what apecore,  myself and possibly Geo are working on.
   There is only one 2sc5200 Kacher transistor. Not two.
Although on Ruslan's newer circuit he may be using two of 2sc5200, to lowered the over-heating.
GeoFusion
Quote from: lost_bro on December 19, 2016, 02:02:51 PM
take care, peace
lost_bro
Hi lost_bro
;) exactly. agree on the math.
You see in Ruslan comments just follow what he commented.
you will see it will fall in place.
One of the secrets of this all is the tuning of the coils, My Opinion. Very important.
Nickz
https://youtu.be/1weV296sjHU?t=36
over here is where I was using them,
without them there is no gain effect as how it does.
but discard this method since I was trying out many schematics,
but seems this is one of the ligit ones.
here still I was not completely on perfect tuning of coils but 1/3 of the freq it should be one
is still working. 1876Khz 1/3 =625khz tesla which under math it works also.
is the workign freq of my tesla kacher
Like I said their are many ways to skin the cat ;).
Yes try the one you have posted, but you will need Tl494 pushpull driver.
You cannot be stuck on one freq, need to able to regulate duty cycle and freq.
Cheerz.
