0 Members and 243 Guests are viewing this topic.
Dog-One
So you did the coax coil aay Grum.  I did not know that.
I have an idea maybe to try based on a similar principal.
A wire wrapped by another wire and the whole thing wrapped
around a former, probably ferrite.  The idea here is to keep the
two wires in what one might consider a transformer, at nearly
90 degrees from each other.
My thinking is this would be the most inefficient transformer
ever made, or ...
verpies
Quote from: Dog-One on January 02, 2017, 08:28:28 PM
ever made, or ...
Not really.  See the attachment
I also have a 2nd PDF on the subject of Parametric Transformers but it is 32MB and this forum will not accept files this size.
Jeg
Quote from: verpies on January 03, 2017, 05:27:19 AM
Hi guys.
The problem for me is that we are right in the middle of the process of moving from what we already know and use,  to impulse technology. Some can say that Impulse tech has many secrets. But what we usually call a secret, actually is an unexplored place that we never been before, and by studying it it's not a 'secret' or magic anymore. KML wires also use the same 90 degree tech to enhance the output.
Coax cable except of its excellent capacity/coupling between the two conductors also provides an imbalance between the outer and inner conductor due to its concentric geometry. This imbalance is necessary in to what we are trying. See leyden jar caps.
AlienGrey
before you all boldly go where no man has gone before (as if that were true) why don't you do your home work ? hmm!
Have a look at your device and ask your self is it in harmony with the collective ? if you think it's a joke, then your wasting your time here, make sure all your wingdings are in harmony. and use Maths to check everything and base your device on the earths resonance.
I know i'm wasting my time telling you all, but check everything including spacing.
So suppose the katcher is related to a 40m grenade coil how would you work out the katcher winding length and considering if you used a spacing between wingdings what would it be in order to capture all the harmonics ?
If our katcher is consider our primary what would our spacing and winding length be for optimum gain be for such a device ?
So before you bin it all have you done this or just built a visual none working replica of some one else's device just using guess work ??
magpwr
Quote from: Grumage on January 02, 2017, 12:16:01 PM
Dear Magpwr.
Happy new year.
Was I on the right track ?
https://www.youtube.com/watch?v=uDofBGk4OCc
Kind regards, Graham.
Hmmm..... It seems you commented at the time..... I should review my videos more often !!   :) ;)
hi Grumage and everyone,
Happy New Year.
We both were experimenting on coax cable around the same time.Neither of us knew about it until i posted my experiment that we knew about it. By sheer coincidence. ;D ;D
Fast foward to the present moment.
Straight to the point base on experimental facts related to kacher or tesla coil which i will describe below
I have attached the one and only clear shot of Akula device during the presentation some group of friends within Akula compound.This was uploaded by someone in this forum some time ago.
This photo reveal few things about the kacher and the direction of the windings as well.
1)There is mix of high Q coil and tesla coil and formed total of around 110 turns in order to achieve the required frequency 1.7Mhz....1.8Mhz if combined with Antenna over the kapanadze coil.
2)If you notice carefully at middle of the primary winding of the kacher at the 3 turns or mid way.The coax cable is stripped of the outer insulation.
After watching the video from MrRomanCorp related to the kacher.It somehow gave me a hint that the end of the coax cable which does not look contacted to anything but glued to the wood.
My suspicion the end of the coax cable is shorted together.The inner core and the outer shield is shorted.At the middle the wire is actually connected to the middle core of the coax.shield is connected all the way
I hope you can visualize in your mind on how the coax will look like.Why is it done this way maybe to increae output from kacher using a transistor.
3)Base on experimental facts by connecting postive at the top of the primary winding as seen in the attached Akula circuit.
This will create more current movement between Earth and kacher as compared to connecting positive at the bottom of the primary near bottom of the tesla coil.
If you connect positive at the bottom of kacher as how it is done for all npn transistor/mosfet circuit to drive kacher.More voltage is present at the Antenna but at the cost of lower current movment between Earth and kacher as verified by clamp meter without taking readout accuracy into account.
4)Voltage at the Antenna needs to be high enough in interrupter mode to burn wire as seen in attachment and also create plasma  at the ferite rod upon contact with metallic object.
Parametric oscillator circuit combined with my simple phase shift circuit(Yes i planned even this before even designing) combine with high frequency interrupter at the correct pulse width and position will generate a 3rd frequency.Yes it does defy my level of understanding in science as found in typical books or theories.
This circuit of Akula can only be decoded by people like myself or anyone with excellcent understanding of Electronics.I shall not release base on what was already posted.
Simple improvement a dual mosfet driver TC4427 can replace 4 VT1,VT2,VT5,VT6 transistors and 2  resistors R11,R21 in the interrupter circuit of Akula.Nothing much to add.
Please do not ask for more or any demo.I have given enough information for 2017.But can you digest my words in the first place?    ;D
