saturnio
Hi guys! I am relatively new to this.
Maybe you can identify if it's a new video.
It seems to be close to making it work, right?
https://www.youtube.com/watch?v=k0rp1Sjkt2M
https://www.youtube.com/playlist?list=PLhG1WObRU5PyxFcRio-c1Taoky3WAoEus
zalmoxis
I'm back with some oscilloscope images ..
yellow & light blue - pushpull
blue - tesla triggering.
I have some windings updates ..
*tesla primary & tesla secondary (0,9 mm diameter; 19 meters ling) CCW
*Antenna i used CCW ALUMINIUM wire
*grenade coil 1&2 layer CCW , 3,4,5,6 CW
*inductor CUT from 19meters to 9.5 meters !!!  why ?!
because using 19 meters + resonant capacitor (330nF + 330nF + 470nF = 1,130uF) the maximum output from the toroidal transformer was only around 78Volts with 75Watt bulb at ~12kHz!!
with 9.5 meter inductor i use (330nF + 330nF) and i have a full brightness BULB with 160Volt at 23,5kHz
Inductor or 9.5 meters 20 windings x 2 layers CCW
the other output from transformer is connected to the upper wire exiting the inductor and then connected to ground.
Till now i didn't get 200Volt output ...
using 2 BULBs 50Watt + 75Watt .. the light drops ... like 20-30%
The inductor becomes extremely HOT!!
Playing with tesla frequency/nano pulser  sync etc ... i get no drop on Amps ... and no increase in voltage ..
any more suggestions ?!
Thanks!
lost_bro
Quote from: zalmoxis on February 09, 2017, 02:57:42 PM
Thanks!
Good day Zalmoxis
Is there a reason you are triggering the Karcher output during the Push_Pull transistor Deadtime?
Push_Pull Deadtime equates to Zero voltage crossing or approx. 90 degrees off from where it should be *if* you are trying to pulse the Karcher @ TDC (apex) of the Current Waveform.
Ie; the Current waveform is approx. 90 degrees out of phase from the Voltage waveform, not 180 degrees out of phase as the Zero Voltage Crossing would have it.
Nice pictures.....
take care, peace
lost_bro
zalmoxis
Quote from: lost_bro on February 09, 2017, 04:53:47 PM
Good day Zalmoxis
Ie; the Current waveform is approx. 90 degrees out of phase the the Voltage waveform, not 180 degrees out of phase as the Zero Voltage Crossing would have it.
Nice pictures.....
take care, peace
lost_bro
Yes,the waveform  after the capacitor who connects the inductor there is where i have the highest peak around 140 Volt if i power pushpul with 12 volt, and around 260V if i power push pull at 24Volt.
When the tesla pulse hits the peak of the inductor wave i have a drop on amps from 2.4 Amps to 2.2Amps
Now i have another problem ... if i power the pushpull at 24volt ... the 160Volt zener diode between ground and drain gets too hot .. i have around 176-180volt on the zenner.
Another interesting thing  one bulb connected 3,3Amps , 2 bulbs connected in parallel  2 Amps .. and the light intensity drops.
I have some chinese 30Amp meters ... of course they are chinese .. the shunt is missing :))
