0 Members and 27 Guests are viewing this topic.
zalmoxis
Ok, i'm back with some more results .. on nano pulser i've got a 3,33Mhz a strange phenomena is happening when i pass 2,5Mhz .. the fluorescent gas lamp turns off ... it behaves just like tesla coil is pushing nothing out ...
so at 3,33Mhz i have no fluorescent lamp working ... it looks quiet .. except that the digital voltmeter, while measuring the voltage on 160Volt zener is playing with numbers ... 200volt -- 1800 volt etc .. this is a phenomena of a working Tesla .. but no fluorescent lamp light ..
I was afraid to touch it.
I've pushed up the voltage from 20Volt to 170Volt on Tesla primary ...still nothing ... then i've found a sweet spot .. it looks that the fluorescent lamp almost show a bit of light when part of it is between the inductor and tesla antenna ... so tesla is working but is kinda silent.
With tesla working the voltage on zenner diode with two incandescent 70watt bulbs in parallel is around 90-110Volt ... with just one light bulb voltage goes to 160-170 ... and also the amps being sucked by the pushpull doubles with just one LOAD.
Still i have no effect while syncing the tesla with push-pul .. what should i do ?
Why do people use between tesla secondary and the antenna that 90 degree coil on ferrite ? i don't use that ... i have no radio ferrite now ... what is the purpose of that?
Why some russians when are touching the tesla antenna you can hear some audio "noise" ? because they power up the tesla from the yoke transformer ?
I have changed the heatsink .. with the old one i've had some sparks between aluminium and drain of the 2sk2611 transistor... and it was a pain to access the bottom of the PCB
How critical is the grenade coil in this process? Are my windings wrong ?
I only get a high output from pushpull at 23,5Khz  and only with 9.5meter inductor .. with 19 meter inductor that frequency drops ..
should i also use 9.5 meter for tesla ?
Should i try another type of grenade ?... should i put the capacitors close to the antenna ?  ;D ;D
I will try to measure what happens only with tesla running and the inductor in short ...
talk tomorrow.
Thanks .. we are on the right way .. i guess
ps: can be the low output of the tesla antenna a good thing ? probably i will try with a copper wire ... am smaller diameter winding over the inductor ..
steadyfield
Quote from: zalmoxis on February 10, 2017, 08:08:07 PM
talk tomorrow.
Hi, Zal
The time that the pulses are triggered is incorrect. The pulses should be triggered on the peak of the CURRENT in the inductor instead of the peak of VOLTAGE across the inductor. From the scope shot "DS1054Z_DS1ZA184351414_2017-02-11_02.32.00.png", I can observe that you are measuring the voltage across the inductor of the grenade, and the voltage is approximately 90 degrees out of phase to the current waveform, so you were triggering the pulses in the wrong time. To do it correctly, measure the voltage across the secondary winding of the yoke. In series resonant, the voltage of sec is IN PHASE with the current. And then set the pulse position on the peak of that wave.
Regards,
Steadyfield.
AlienGrey
I don't think the grenade windings are correct according to Russian winding spec in order to be set up correctly.
See attached diagram. Sec winding also has to be 1/4 wave not 1/2 wave.
Also see Stalker PDF and video setup.
https://docviewer.yandex.com/?url=ya-disk-public%3A%2F%2FE2wEZhfsuwwDHsDFCDCclpygCN2fsMm4Jfscppreav0%3D%3A%2F%D0%A0%D0%B5%D0%B7%D0%BE%D0%BD%D0%B0%D1%82%D0%BE%D1%80%20%D0%B8%20%D0%B8%D0%BD%D0%B4%D1%83%D0%BA%D1%82%D0%BE%D1%80%20%D1%81%D1%85%D0%B5%D0%BC%D0%B0%20%D0%BD%D0%B0%D0%BC%D0%BE%D1%82%D0%BA%D0%B8..pdf&name=%D0%A0%D0%B5%D0%B7%D0%BE%D0%BD%D0%B0%D1%82%D0%BE%D1%80%20%D0%B8%20%D0%B8%D0%BD%D0%B4%D1%83%D0%BA%D1%82%D0%BE%D1%80%20%D1%81%D1%85%D0%B5%D0%BC%D0%B0%20%D0%BD%D0%B0%D0%BC%D0%BE%D1%82%D0%BA%D0%B8..pdf&c=589f0ecd3058
Stalkers grenade coil Info
Hot conclusion inductor cold output of the coil
Kazhy layers 1 and 2 contain a quarter (Lk / 4) of the total wire length (Lk)
горячий вывод индуктора холодный вывод катушки
Кажый 1 и 2 слои содержат по четверти (Lк/4) от общей длины провода (Lк)
Third layer is wound on half geometric length 1st layer
3-й слой мотается на половину гео метрической длины 1-го слоя
the length of the remainder distributed between 4.5 and 6 layers for fitting inductor (Bk) under the settlement
остаток длины распределяется между 4,5 и 6 слоями для подгонки
индуктивности катушки (Вк) под расчетную
length of wire inductance () is a quarter (Lk /4) the length of the coil wire (to).
The inductance of the inductor (Bk), multiple inductor coil (Lk)
длина провода индукт (Li  ) составляет четверть (Lк/4)
длины провода катушки (Lк).
Индуктивность индуктора (Вк), кратна индуктивности катушки ( Lк)
winding Geometry inductor is different, for fitting inductive spine winding length
Геометрия намотки индуктора различна, для подгонки индукти
verpies
kampen
Russians Create Free Energy Device! It's Real!
Found another free energy device - this time from a team of Russians and South Koreans!
The company is looking for distributors also.
Russians and South Koreans team up to create a 10KW free energy generator ready for mass production.
Spread the word through all alternative media!
No more excuses - free energy is here now.
These guys are looking for distributors in all countries.
You'll see the 10KW version and a demo 1KW generator in this video.
https://youtu.be/qKUbTGoRP0I
