0 Members and 58 Guests are viewing this topic.
verpies
Quote from: NickZ on March 24, 2017, 09:50:11 AM
Are you saying that I've made a mistake on the connections, or that the topruslan7 schematic is wrong.
If you are copying topruslan7 schematic then you did not do anything wrong.
As to the question whether that schematic does not follow the manufacturer's application note, Lost_Bro and Itsu just beat me to the explanation.
What should I do about it? And why? Please explain.
That depends whether you treat the topruslan7 schematic as gospel or work in progress.
Is the video I posted a link to "How to use a TL494" also not showing the dead time?
I don't know, I never watched it, but I read the TL494 datasheet and the manufacturer's Application Note.
As it is showing the same thing, pulses between the peaks, same as mine.
What peaks? Are signals on TL494.pin 9 & 10 these peaks ?
I'll change whatever needs changing, just let me know what actually is not right, and why.
If it works for you then don't change it.  But if you hit a wall with the topuslan7 schematic, then you might consider using the TL494 like its manufacturer has intended.
NickZ
    Guys:
   The changed have been made as suggested to my TL494.  There are definite changes as compared to my previous set up.  I'll post another short video tomorrow showing the way it's working now.
itsu
Quote from: AlienGrey on March 24, 2017, 06:57:20 PM
it might seem a strange thing here to say or ask here but what does this part of the circuit do ??? One might think the 17.68 khz is 100 times the 'F' of the Tesla coil 'yeah' but its free running and not locked in frequency or phase ! Also in other devices the push pull is used to demodulate the 'F' to 50 or 60 hz grid frequency and also isn't the Tesla coil the wrong way round since we are counting power peeks and not the other way round ? any one any ideas ?
Well you should ask Ruslan or the one who designed it, but i understand it will generate the push pull signals at a frequency in the 17, 27 or 37 KHz range.
This together with the Kacher resonance frequency in a 1:50. 1:60 or 1:100 relationship should provide the "magic" via the Grenade coil to pull power from the ground.
Apparently, the stability of the TL494 needs to be great like within 100Khz, so a PLL system would be an advantage (and we have already seen a PLL setup (Oleg)), but it
seems not required as we have seen setups without any.
Itsu
Dog-One
any one any ideas ?
You cannot measure or properly manipulate what you cannot see.  That's the first problem you have to solve.
You can be assured Ruslan, Akula and others will never tell you the secret.  They are not going to spoon feed
anyone.  You know what that means...   You have to think for yourself.  You have to ask yourself the question,
"What is it they are really looking at to make this all work the way it does?"
nelsonrochaa
Quote from: Dog-One on March 25, 2017, 09:34:49 AM
You nailed it in right point !  ;)   Dog-one .
For those who consistently create assumptions of how particular circuit works is the right question to ask:
How should be made even fake to that circuit  work in the way like it does , in that way everybody gain , because learn under that process, exactly the opposite  happens because , just copy something from someone,  could be made deliberated just to create diversion and maintain people far way from the goal .
Cheers
