0 Members and 255 Guests are viewing this topic.
NickZ
  Verpies: After some more testing, I can see that both fets are ON at the same time.
   What can be done about it?  If I go back to your suggested connection method, I'll only have one channel working. And even that one channel may not be working right.
   AG: the frequency is high, barely able to hear it. Don't
know exactly at what frequency until I do the math on it.
But,  it doesn't matter until it's working right.
verpies
Quote from: NickZ on April 03, 2017, 08:13:10 PM
What voltage do you have between pin13 and pin7 ?
NickZ
Quote from: verpies on April 03, 2017, 09:38:55 PM
  As it is right now, my multi-meter can't read the voltage between pin #13 and pin #7. Possibly due to high voltage interference  from the kacher. It should read 12v, though. Maybe if I disconnect the kacher
   I'll keep looking into the problem tommorow, as it's getting late here tonight.
   I was getting the same signal as I had shown at first, out of the TL494 and out of both drivers. Which I checked just beforel I added the snubbers, and connected the push pull up to the yoke and to the rest of the system.
verpies
Some scope shots would really help to diagnose the problem. Even from a blurry scope.
Both mosfets should not be turning on at the same time. If the 494 is producing complimentary outputs from pins 9 and 10 with some dead time as it should be doing, then there must be something wrong downstream.
