0 Members and 219 Guests are viewing this topic.
stivep
thank you guys for your response.
simple answer.
Verpies that  Mill whatever guy.
why he has not get to me with that. I have  everything to make it. look at the pictures  MY MODEL was  special order that goes to 3180 CELSIUS =5756 Degree Fahrenheit
Is it he is full of  scam  and trying to extract money from less fortunate in brain power but quite well with money ?
Verpies  convince me and you  will be beneficiary along with  rest of you charge free.
I do not need fancy ball of https://www.youtube.com/watch?v=AhIoDxjaibQ&feature=youtu.be&t=3756
In my lab heat can be achieved and phenomena can be spot.
The important is to see energy in vs energy  out.
Addition of two graphite plates in the vise or clamp makes chamber.
Vacuum if required  can be  achieved by placing all structure in vacuum jar( chamber I have it too) Photo.
Wesley
Wesley, you definitely have the best lab of any of us. I just have one question:
What's a Putlerer?
zalmoxis
Hi, it's been a while since i've posted something here. I've found something that i can't explain to myself.
I want to understand what and why this happens.
I've attached a coil diagram.
At a certain frequency on the pushpull driver at around 17Khz something happens on the output of the grenade coil and on the output of the series resonance capacitors (340nF) and i have 68nF on the grenade output.
The frequency on those spots jumps from 16Khz to 54Khz !!!
Under the grenade coil i use an aluminium coil.
My question is why I get 2x-3x in frequency change.
Light blue sines = series capacitor.
Dark blue =  grenade output
In the last attachment is how the scope images used to look without aluminium coil on the first layer of the pipe.
Till now i did not get any amplification effect. Tried with multiple tesla secondaries and primaries, aluminium/copper different lengths.
On this setup i have used a TV Yoke tesla byfilar primary with 2x12Turns 1,5FY wire and in the secondary normal 2.5 MYF wire 10 Turns.
Good luck!
magpwr
Quote from: zalmoxis on April 10, 2017, 05:59:06 AM
Good luck!
hi zalmoxis,
I assume you are using the sergey circuit in interrupter mode to drive tesla coil.
You will notice that at resonance "sine wave base on your attachment" from 3...4..turns there is no changes in output frequency since kapanadze coil was not given a chance to resonante on it's own."Tight coupling" :(
It's the main reason why i find it's hard to convince people that Ruslan is fake whom presentation uses L/C resonance.
If you slowly change the tesla coil frequency via the interrupter circuit and maybe need to slowly change the interrupter position in waveform.
Then you will suddenly see the output becomes a "sine-wave" but of higher frequency.
Do note that i only achieve this effect if i select the jumper from one of the output from PWM or IR2184 output."No effect noted if i connect to both 2 PWM or IR2184 output" via 1n4148 diode to nanosecond circuit of Oleg which is tweaked for usec range.
Please do  try it out.I am unable to advise further.
zalmoxis
Quote from: magpwr on April 10, 2017, 09:39:12 AM
hi zalmoxis,
I have forgot to mention that this effect is present also with Tesla OFF.
Yes i do use the Sergey diagram.
So you say that i have to setup push-pull on some "Edge" where then tesla can create this higher frequency effect?
