0 Members and 326 Guests are viewing this topic.
AlienGrey
Quote from: verpies on October 07, 2012, 10:40:37 AM
According to the attached schematic, the transistor Q3 will invert the output of the NAND Gates in Integrated Circuit U3.
The polarity of the low duty-cycle pulse appearing on the output of U3 is determined by the switch S2.
Also, because Q5 is a N-Channel MOSFET then a positive voltage on its gate will make it conduct between Source and Drain.
If Q5 remains conducting too long then a destructive current will flow through L5, T1 primary and Q5.
P.S.
The attached schematic is identical to yours (identical circuit) but it is translated to English and has four additions:
1) Description: "Monostable Multivibrator"
2) Description: "DSRD Driver"
3) Description altered to: "DSRD Nano Pulser"
4) Component designations.
Hi guys can we just change the subject a moment and get back on track ????????
Have a look at this diagram of the ORIGINAL!  ok
can i draw your attention to this circuit for a while, in particular, the toroid, notice no details are given on this device no ferrox permeability details or winding details and also note the drive is directly connected to the grenade L1 primary, or the matching of an unknown impedance to a High impedance factor I find it unbelievable no one has picked up on this so far, has anyone got any information as I can find nothing on any of the early pages ?
oops just noticed the nano-drive circuit, notice the extra drive inverter transistor ;) err that's going to cause a problem or two ;) perhaps a PNP would do better there.
AG
AlienGrey
Quote from: Vasiliy Buslaev on October 04, 2012, 03:42:31 AM
Hi guys!
Posted photos of "green transformers". This is what I found in my pantry. This is a military standard for special transformers, of which there are a huge number of specifications. Produced on the U-shaped cores and toroids. I disassembled the transformer, such as the Dally.
The core is made of an alloy of "alsifer" (aluminium, silicon, iron) or mu - permalloy to avoid saturation. Cores are designed to operate at low frequencies up to 10 kHz, where the use of ferrites impossible.
Dally just picked suitable transformer for his DC-DC converter.
To make such a transformer  I can recommend the rings
made out of u-permalloy.
Vasiliy
0 special devices !! a yoke ????? hardly 10kh Nickel Mu metal alloy!
It might look like junk but it most certainly is not!
AlienGrey
forest
Quote from: AlienGrey on June 24, 2017, 03:07:34 PM
Can someone translate this ?
https://www.youtube.com/watch?v=oi7qViCGa0Q
Why ? It's nothing important, pure speculation about hidden batteries in kapanadze green box. We all know that it's not possible, because of older video with the same coil
PolaczekCebulaczek
this old fart Kapanadze does not hidden any batteries, he found a method of transmitting energy in near field through ground, Wesley had seen it, and many russian FE style devices are using this same method.
