0 Members and 226 Guests are viewing this topic.
cheappower2012
Hoppy I don't think the transformer will heat up, I know that it will thru experimentation.
There is a lot of information in the 2012 device video/pictures as to how to configure the transformer also the tpu toroid is configured in a very similar way.
The buzzing in the 2004 device is coming from the inverter not the device.Its a transformer
being pushed pass its current limit.The 2004 device requires a given amount to start,its no problem
when he runs the inverter thru the battery.If he runs the ac plug with both the transformer for looping
and the inverter  connected to the battery there's no buzz
When he disconnects the battery and has the the output of the
transformer used for looping connected and plugs in the ac cord then he gets the buzzing,when
he removes the ac plug it stops because the device is powering the inverter.My opinion is
there's a small 1 to 1 low ac wattage transformer  in the inverter unfortunately it can barely start the device
this is the cause of the buzzing.Why this inverter would have this feature is strange but it may have had a function,its not an ordinary inverter.
Belfior
Tariel is a crafty guy, that had to make due what they had at the time he made his invention. He would also like to get some coin for it, even he said he found it by accident. This is why he also has all these smoke and mirrors hiding the simplicity of the invention. The guy has no scope or a high tech signal source. One more thing that supports the accident theory.
I will post any findings and schematics don't you worry. That is if I ever find out anything. I will make an instructional video in Hindi and subtitle it in English. That should get it of the ground. I got a job, so I get enough money to eat. Money is an illusion anyway. We need free energy, so we can start exploring our solar system. You can't put a price on free energy.
T-1000
Hi all,
In regards to circuits it does not matter what you use to get same waveforms as they were shown by Ruslan,Sergey and others. What matters is the circuit ability to fine tune frequency, duty cycle, voltage ranges and other variables as required. Which means for example, the push-pull circuit is just not fixed 50/50 flip-flop but also have PWM control after forming signal. And the Tesla coil driving circuit shall work not only in katcher mode but also in nanopulser mode with variable frequency, voltage, duty cycle and external trigger signal.
One of things in addition what is most important to realize - those devices do not work on copy/paste methods and unless you know exactly what makes those clocks tick it will be long way until it will be find out...
Cheers!
Belfior
Quote from: T-1000 on August 16, 2017, 10:16:50 AM
Cheers!
Well said and my point exactly.
Hoppy
Hi Cheappower,
The attached poor quality clip from the 2004 video shows a black box (like later used in the green box device) sitting on what looks like a round stall. There is a thick black cable plugged into the box with what looks a bit like a Euro mains connector. What do you reckon this could be? There also appears to be a white wire from the box going over towards the lights.
