0 Members and 92 Guests are viewing this topic.
slapper
with the core material that i've been playing with, there is a correlation with the on time of the mosfet and the peak voltage of the spike immediately after the mosfet is switched off.
i think the core material requires some time for it to get charged up depending on the energy applied.
we are not alone :)
NickZ
  MenofFather:
   That hand drawn diagram is showing that the center tap of the yoke is receiving  25v,  not 220v. But that diagram is said not to be accurate, or to be trusted.
   I know that the yoke's 3 turn coil goes to the 5uf capacitor then to the resonator coil, and back to the yoke. That is not the question.  Nor is it connected to the big air coil, either.
   My question is still how much voltage/current is going to the center tap of the yoke.  As it is not going from the 220v Ac to Dc rectifier then direct to the yoke, as it is going first through the driver circuit to be pulsed and the duty cycle and frequency adjusted for optimum gain, then to the yoke center tap. I think.  If the yoke were only getting 25v like in the diagram you re-posted, that would result in practically no output (current) after the 3 turn yoke coil. Which is what I'm getting. Maybe this is how it's supposed to be. Even if I give the center tap 1000+volts, hardly anything comes out of the 3 turn coil, only empty fluffy voltage with no current.  So, there may be something very wrong with what I'm doing.
And giving the yoke pulsed high voltage with little current is not going produce the expected results.
It needs mayor current to do the trick, and work like an induction heater.
  I think that so far no one here has figured out just what is going on, and how it's supposed to work.
And to relate this to everyday electronics, is not going to cut it. As none of this is what we were previously taught.
  The problem in all the self-runners is the unresolved transistor heat issue. So, they won't run very long without burning out. Only for a few minutes, possibly. That's why Akula does not connect the 500 watt bulb until the last part of the video, then only for a couple of minutes. This problem may have possibly been resolved in his last video, using a thick ground connection, and a different lay out.
But, it may be that the draw is way to high for the system to handle, still, as he is not lighting his house, or heating it, as he said, previously.
All of this could have been resolved, if he would have e-mailed me back.
  Back to the wild goose chase.
Thaelin
   The FWBR getting hot can be fixed by using multiple diodes on each leg of it and using a heat sink. As for the Fets, jeeze, use multiples here too. Want to move the air, put a fan on the sinks.
   As you all know, I have been working at the tl494 pwms. Finally gave up and will just use a 555 to drive the mot I have now. It was just for the HV anyhow. I am trying to get my head around how the coils actually affect each other. Then there is the mini TMT in the middle of all this. Darn sure it boils down to where the standing waves appear. Back in the chase again.
thay
MenofFather
Quote from: NickZ on June 04, 2013, 01:15:15 PM
  MenofFather:
But, it may be that the draw is way to high for the system handle, still, as he is not lighting his house, or heating it, as he said, previously.  All of this could have been resolved, if he would have e-mailed me back.
"[size=78%] That hand drawn diagram is showing that the center tap of the yoke is receiving  25v,  not 220v. But that diagram is said not to be accurate, or to be trusted.[/size][size=78%] "[/size]
[size=78%]This diagram maybe that from that akula begin, or it maybe first his generator free energy works on 25 volts.[/size]
"[size=78%] My question is still how much voltage/current is going to the center tap of the yoke.[/size][size=78%] "[/size]
[size=78%]Voltage is 220 volts. Curent is about 2-4 amps. Because if it be 5 let say amps, then it can burn mosfet. If be 0,5 amps, then mosfets not makes be hot, I remebber he say that mosfets makes hot or something that.[/size]
forest
NickZ
The heating problem tell us there are many many amperes running through them and I agree with that... but seriously eliminating transistor is a next step ,too much ahead,maybe Akula may fight  this issue now, but we don't...imho You are good observer like many here , just take notes about various effects and you will solve that....
