0 Members and 277 Guests are viewing this topic.
Void
magpwr
Hi everyone,
Although i am no longer involved in kapanadze replication attempts.
But i need to give closure even though it is considered extremely hard information to swallow for many.
Some of you may recall i was using parametric oscillator using LM393N connected to 2 hex inverter then to my divide by 3 counter as previously released in my youtube channel.
The divide by 3 output was was fed to the single to dual channel splitter IRXXXX powered by 12volts then fed to dual channel mosfet driver.
The full details on i achieve around 80khz sine wave at output.L/C from toroid resonance is around 30khz but this is divided by 3 so it's running at 10khz.
But once the kapanadze coil(interrupted oleg circuit hybrid which was posted by me) hit the right frequency within 20khz around 1.7Mhz.The output of kapanadze coil would be producing around 80khz sine wave.
Mosfet driven at 10khz but kapanadze coil is running at 80khz.Sine wave of higher voltage.
But the sad part is i observed no OU maybe i am living in high rise or i have wound the coil wrongly maybe too few/many turns.Only 2 missing possibilities.
From this experiment there was a unexpected or maybe unrelated incident which i may release for my 100th video maybe.
I have somehow managed to generate orange plasma which i nicked "Firefly" from the output of mosfet driver even though it was connected to my SIC mosfet.
Have anyone in this world generated "tiny orange plasma" with no smoke from output of mosfet driver(1.7Mhz interrupted) powered at low voltage 20volts with no increase in current.
(But i can't assume it's the same hydrogen plasma as mentioned by Akula in his old deleted video with translated pdf documents.)
The soldering flux underneath mosfet driver created approx 431kohms between output and ground before it was cleaned off.
This in theory can be replicated in tap or salt water if 2 metallic points is close together.
Good Luck with nothing much to reveal from my end. :-*
Void
Welcome back magpwr. Thanks for the update.
Yes, achieving OU would appear to be no easy matter. :)
I saw a yellowish plasma once, but it was not related to these devices.
It was a different setup. I forget now what my exact setup was, but I was generating
high voltage and getting yellowish colored plasma. I think I tried to take some video or
pictures at the time, but the camera wasn't picking it up very well.  I guessed the color
was maybe due to some alloy in the metal or wire I was using, or something along those lines.
All the best...
NickZ
   Geofusion
   Welcome back, we've missed you around here.
   After watching your first new video, I decided to disconnect the 3t and the 168t grenade coils. And I found that I could produce the same RM (Radio Moscow) signal sound as with the grenade connected up. Sort of surprised me at bit, as I've not seen that happen before.
   I'm still struggling with the snubber heating issue, no matter what I do. Can you tell me what snubber caps and resistor you are using for your set up? The snubber caps and resistors?
   Can you also let us know what voltages you get between the fet's drain and source. Please.
        Thanks,
        NickZ
